HOUSE Motorsports ::: BBi Autosport 997 GT3 Street Cup Exhaust
BBi Autosport Porsche 997 GT3 Street Cup Exhaust Upgrade
BBi Autosport Street Cup Side Muffler Bypass
Shedding weight is one of simplest ways to add performance to your Porsche. Unfortunately, reducing weight on the already slim GT3 is rarely an inexpensive task and the factory exhaust system is already very well designed for optimum power delivery. The only drawbacks to the factory system is a muted exhaust note that was designed to comply with the local laws and appeal to a wide customer base, and the excess weight from the muffler packing material.
We addressed those flaws when we designed our exhaust system for the 997 GT3. Most other aftermarket exhaust systems on the market replaces the secondary center muffler and the performance gains and weight savings are minimal. The factory secondary exhaust weights approximately 20 pounds and the average secondary muffler bypass weighs approximately 7 pounds, which equates to only 13 pounds of weight savings.
We took a more unorthodox approach and bypassed the much heavier primary side mufflers. The primary mufflers are weigh approximately 44 pounds total while our bypass pipes are 4 pounds in comparison. The result is a substantial reduction in weight behind the rear axle which significantly improves handling and less restriction to produce a much more aggressive exhaust note.
Key Features
- Produces deep aggressive exhaust notes at lowers revs & exotic high pitched exhaust notes at higher revs
- T304 stainless tubing
- Meticulously TIG welded
- Brushed stainless finish
- Stainless hardware and clamps
- Factory secondary mufflers and catalytic converters are all retained
- Direct bolt on replacement
- Hand built to order
- 100% emissions legal
- Will not void warranty
OEM Mufflers (44lb) vs BBI Side Muffler Bypass (4lb) Comparison
BBI Side Muffler Bypass Installed
Key Features
PelicanParts.com
997 Vendor Classifieds
Aug 20, 2015 02:39 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 20, 2015 02:38 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
