997.1 GT3 Changing clutch - what else to do
Old Dec 28, 2016 | 01:49 AM
orthopod's Avatar
orthopod is infamous around these parts
Hey there,
I have a 2007 GT3 997.1 with PCCBs . Had it for 7 years, now at 55k miles, and the clutch is slipping. This is about average life expectancy for heavy Los Angeles traffic as per the dealer.
I do some high speed track several times a year, and autocross 4-5x/year as well
Any suggestions on what else should be done while clutch is being redone? I've bought steel brake lines, and am going to check out the brake pads myself. I've read not great things about going to single mass flywheel - do others disagree?
Already blew my coolant line into the engine a few years ago.
Thanks in advance.
Old Dec 31, 2016 | 04:55 PM
Harry Da Hamster's Avatar
Harry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud of
Also planning to change my clutch soon, albeit a 997.1 Turbo. Following for peoples opinions...
Old Jan 9, 2017 | 06:39 AM
love2drive's Avatar
love2drive is infamous around these parts
Switch to the GT3RS single mass flywheel? That may take daily driving over the top for you though.
Old Jan 13, 2017 | 12:42 AM
mike2016's Avatar
mike2016 is infamous around these parts
RS flywheel + RS crank pulley.
inspect coil packs
Old Mar 4, 2017 | 10:35 AM
stealthlogics's Avatar
stealthlogics is infamous around these parts
If you don't mind what's that cost 3k?
Old Mar 5, 2017 | 06:32 PM
orthofrancis's Avatar
orthofrancis is infamous around these parts
Logging in under a diff name, as I can't reset my old name.
But yeah - roughly a little over $3,000 to just change the clutch.
I went the whole way - RS 4.0 clutch and pulley, LWFW, Guards LSD, Sharkwerks coolant line pinning(I already blew my lines once before - if you track it at all it's a must) and RMS (rear main seal - easy to do since engine was out)
I don't think I'd put the light Weight Fly Wheel in again as the rattle it makes is annoying, and I think all that rattling may cause something to loosen up eventually. I don't really notice any acceleration difference with it in. If you're a hardcore tracker, then the weight savings are worth it.
