GT2 Front Camber Plates
Old Mar 22, 2006 | 01:55 PM
flynduc's Avatar
flynduc is infamous around these parts
Any good suggestions for Front camber plates for 996 GT2.
I want to add more camber to front on my 03 GT2.
Old Mar 22, 2006 | 01:58 PM
Hamann7's Avatar
Porsche Fiend
Hamann7 is infamous around these partsHamann7 is infamous around these parts
Manthey Racing makes some great ones.
Old Mar 23, 2006 | 12:43 AM
NJ-GT's Avatar
NJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud of
The GT2/GT3 share the same stock camber plates.
I've the Manthey Racing camber plates on my car. They allow a minimum of -3.0 degrees on my lowered car up to -4.0. They increase caster by one degree as well.
You can also remove the three studs from the stock camber plates and reinstall them on the other three holes. This will give you -2.5 to -3.5 degrees. The downside is the decreased caster.
Or you can add camber shims to the lower two pieces control arm, increasing track and camber at the same time. 7mm are ok to get a max of -2.5 degrees. The downside is the rubbing on the fender liner.
Or you can drill the holes on the strut towers to get up to -2.5 degrees. I won't do that unless I know the integrity and rigidity on the strut towers is not compromised.
Old Mar 23, 2006 | 08:46 AM
flynduc's Avatar
Thanks for the info.
Sound like the first choice is the way to go.....
Enemy
Nov 10, 2015 08:01 AM
The Oss
Aug 24, 2015 08:19 PM
TrackOne
Aug 20, 2015 12:56 PM
m_motorsport
Aug 19, 2015 03:34 AM
