New shoes for the GT3Cup Arrived= Carbon Dymags! Nice Check em out
Fabryce-
Thanks for the clarification- before reading this thread I didnt know the first thing about composite wheels. There is no question that Dymag knows wheels, and I am interested in seeing how the application works for you. Unsprung weight makes all the difference, and when racing, we all know it is about getting that 100th of a second.
Keep us updated as the wheels are used, and Im dying to see pics of them on the car!!!
Speechless.
Anybody that follows bike racing knows Dymag is the ONLY one making composite wheels worth buying. It's a rock solid product. Those are art.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
Originally Posted by damon@tirerack
Speechless.
I have seen more bst's on bikes then I have Dymag's.
Originally Posted by Fabryce@GMGRacing
When speaking with the Dymag I to asked about the wheel shattering and as it was explained to me the wheels -actually have a allot of elasticity from the composite material so the wheel barrel will actually spring back to original shapre before shattering... A standard metal barrel ( alu or mag ) will bend or break much quicker than this wheel will shatter.
While a metal wheel may deform before a carbon wheel will shatter, which really depends on the wheel and the impact, virtually all alloy wheels are malleable to some degree. They'll bend before they completely fail. Composites will not. They'll either crack internally (hence x-raying) over time, and eventually fail completely without warning, or catastrophically fail all together.
So, as I said, they really have no place in a street application.
On a race car, personally, I'd have to weigh the weight reduction against the posibility of being able to finish a race with a slightly bent wheel, or at least make it to the pits.
Here's why I won't use carbon wheels on anything:
Originally Posted by Simba
If someone said that, they don't understand their product very well. Carbon/epoxy composites-- ALL of them-- have exactly zero elasticity. Zero. If you bend them, the cured resin between the layers will fracture, similar to how paint will "spider crack" on rubber surfaces if bent beyond a certain degree. While a part may not completely fail on the first deformation, it is very easy for a part to cumulatively fail.
Down Boys-
Lets not all start bashing carbon wheels, Im sure I can show you pictures ( via the internet )of other metal wheels that have failed just as bad if not worse.
Everyone is entitled to there own opinions - No doubt...
I am sure there are circumstances that lead up to the failure etc etc..
So its safe to say that Simba is Not a Carbon wheel fan....... LOLOL???
They sure do look cool, though.
Also, to be fair, Dymag does make the best wheels of that sort I've seen, and their two-piece version with the magnesium centers are much, much stronger than completely carbon wheels.
Originally Posted by Blang.Bling
And some how I knew that picture would come into play here. Was a nice looking duc before too.
And yes, it certainly was pretty beforehand.
Fabryce, how much more maintenance is required of the carbon wheels versus others? I would suspect as Simba pointed out above that the carbon wheels will require more maintenance (i.e. inspection) to ensure you don't have a critical failure.
