996 GT3 question
Originally Posted by Formula1
no. it's simply been vacuumed. seen it before
GT-3 Carpeting
Justin is correct, either a DAS roll bar or Brey-Kraus harness bar was installed. Both of these mounts to the rear shock mounts which are under ther rear carpeting and the slits are made to clear the bar's mount.
Just as you where told, behind the carpet glued to foam rubber there was a roll bar that bolted to the top of the rear shock towers. Depending on marks on the floor pan - seat belt connection area, that may give you a better idea how they mounted the lower part of the bar. Are you trying to figure if the car has been tracked?
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
996 Vendor Classifieds
Aug 18, 2015 03:45 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 18, 2015 03:43 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
