Rear main seal
Old May 3, 2007 | 05:37 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
Mobil 1 and some other synthetics will do that to seals. Mobil 0W40 is the worse. When will you guys learn?
Old May 3, 2007 | 05:51 PM
Ryan in SD's Avatar
Ryan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to all
Yikes, why cant they fix this after all these years? Porsche better get their **** streight.
Old May 3, 2007 | 05:57 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
Magically my TT with positive crankcase pressure and 0W40 doesn't leak. TT's have been out for almost a year in greater numbers with no reported RMS leaks. My educated guess is that it is not oil related
Old May 3, 2007 | 09:20 PM
TT Surgeon's Avatar
Originally Posted by Marc997GT3
Good thing mine is now for sale
Now what? A GT2?
Old May 4, 2007 | 06:49 AM
Mussel Kar's Avatar
Mussel Kar is a jewel in the roughMussel Kar is a jewel in the roughMussel Kar is a jewel in the rough
Originally Posted by K2@Brandywine
As soon as the dealer has the correct parts in hand, it should be about a 2 day repair. Thing is that the GT3 and GT3 RS parts are not commonly an "in stock" item, and most of the time, they have to be shipped from Germany which could take up to two weeks.
I am suprised to here of so many GT3's having this problem. We are all aware of the vast problem with the regular 996 rear main seal problem, but typically the GT3 and turbo seals are far less likely to leak.
As stated before, the more one of these cars is driven, the less chance of oil leaks. The other function of oil (besides the obvious) is to keep the seals lubricated and moist. It is when the seals become dry that leaks start.
Kevin Hines
Is driving it a day or two a week enough? Will 4 track days later this month help it?
Old May 4, 2007 | 08:37 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Then why is factory fill Mobil 1 0w-40 ?
Are you sugessting non synthetic oil ? That sounds rediculous to me.
Old May 4, 2007 | 08:53 AM
Marc's Avatar
Marc is just really niceMarc is just really niceMarc is just really niceMarc is just really niceMarc is just really nice
Originally Posted by C4S Surgeon
Now what? A GT2?
Nope
Old May 4, 2007 | 08:54 AM
Marc's Avatar
Rockit you forget rule #1 the factory knows nothing of how to setup a car and what it needs they only spend 100's of millions on R&D
Old May 4, 2007 | 10:10 AM
Yup. Porsche engineers are GODS. How many times have they changed their PAID approved oil listing? Which generation of seal are they using know. How many engines have had to be replaced? The second gear pop out issue was deliberately engineered by Porsche...wasn't it? and on and on and on.....
Many other auto manufaturers spend a hell of alot more on R&D than does Porsche, so by your logic, their products must be better? Better go out and buy a Ford then.
Old May 4, 2007 | 11:40 AM
K2@Brandywine's Avatar
K2@Brandywine is infamous around these parts
Most of the time, when I see a car that is driven less than 5000 miles a year it has some sort of oil leak. So I would venture to say that if you were to drive the car once or twice a week you should be good. This is of course not a definate answer as my crystal ball along with my magic wand is in the shop for repairs.
Old Jun 6, 2007 | 01:29 PM
Mussel Kar's Avatar
The leak seems to have fixed itself. No drips after the last three times out. Either that or I have no oil left.
Old Jan 8, 2008 | 08:38 PM
Mother's Avatar
Mother is infamous around these parts
I am requesting the 993 varient rms as it has a different seal clamping mechanism than the one used on 996 GT3 964 blocks.
Mine is leaking on my 996 with the 997 seal and it was suggested that the 993 seal works well. What do you mean by variant 993 seal and part number if you have to see if I can try.
Old Jan 8, 2008 | 10:31 PM
porschenut911's Avatar
porschenut911 is infamous around these parts
This is just unacceptable, they need to redesign their seals and dealers need to stop with daily driver BS. The car shouldn't leak, period. I had my Acura TL sit in the garage for months and months over 3 years and not a drop of oil.
Old Feb 3, 2008 | 11:56 AM
cdy's Avatar
cdy
cdy is infamous around these parts
My RMS has been replaced twice at 8k and about 16k in my '04 GT3. Looks like it might be never ending. The process was very quick and easy under warranty, though. It makes a compelling case for an extended warranty.
Old Feb 3, 2008 | 11:58 AM
sharkster's Avatar
we see a few gt3s and rs' (not ours yet) with the RMS issue. I overheard James talking to someone about it (need to confirm this) but the seal they are using is an older style one from the 996 days.. I'll try to get more for you but either way it's not a "big" issue. Not that it really should be an issue I know.
