Lamborghini Vendor Classifieds vendor classified area...do not post here unless you are a forum sponsor
Akropovic Slip-On Titanium Exhaust for Lamborghini Gallardo LP550 & LP560 Coupe !!
Old Apr 14, 2014 | 01:45 PM
need4speedmotors's Avatar
need4speedmotors has a spectacular aura aboutneed4speedmotors has a spectacular aura about
Need4Speed Motorsports | Lamborghini Gallardo LP550 & LP560 | Akropovic Slip-On Aftermarket Titanium Exhaust
PM or Email For Pricing!
Mike@need4speedmotors.com
(888) 714-7467 and ask for Mike for pricing
Akropovic Slip-On Aftermarket Titanium Exhaust for Lamborghini Gallardo LP550 & LP 560
The precision-engineered titanium alloy Slip-On performance exhaust system reduces the weight of this supercar and improves handling. We’ve extracted additional power through improved gas-flow dynamics and a drop in back pressure. To complement our muffler design, we’ve added our well-known cast titanium dual-mode exhaust valves to create a virtual symphony from the large displacement V10. If no optional Wireless kit for adjustable sound is used, at lower engine speeds and during cruise operation the valves are closed and produce a deeper and sharper exhaust note. At wide-open throttle the valves open, releasing the full fury of the engine. The driver can control the sound with the Wireless kit. Complete the look with a set of four exquisite tailpipes in carbon fibre.
When installing Akrapovič aftermarket optional down pipes with sports catalytic converters or without catalytic converters, which are developed for use on closed tracks only, remapping the ECU is mandatory. When installing Akrapovič aftermarket exhaust system that was developed for use on closed tracks, we recommend remapping the ECU in order to prevent potential »check engine light« warning signals.
Name:	lamborghini-gallardo-lp560-4-coupe-spyder-akropovic-titanium-slip-on-line-aftermarket-exhaust-01.jpg
ID:	359707   Click image for larger version
Name:	lamborghini-gallardo-lp560-4-coupe-spyder-akropovic-titanium-slip-on-line-aftermarket-exhaust-02.jpg
ID:	359708   Click image for larger version
Name:	lamborghini-gallardo-lp560-4-coupe-spyder-akropovic-titanium-slip-on-line-aftermarket-exhaust-03.jpg
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Sep 14, 2015 06:42 PM
albert@velosdesignwerks
Lamborghini
Aug 22, 2015 09:03 AM
Lamborghini
Aug 20, 2015 10:15 PM
