G-Spyder Engine Cover
Old Jul 19, 2008 | 01:32 PM
vk430gt's Avatar
vk430gt is infamous around these parts
hey guys, after looking for it in search i couldnt find anything. But i was wondering how do you open up the engine cover for the gallardo spyder? i know theres no latch or anything but is there any little tricks to open it, other than when you put the top down or up? and how do the service guys change the oil when you cant even get to the engine?
Old Jul 19, 2008 | 11:53 PM
LamboRick's Avatar
LamboRick is infamous around these parts
According to Motor Trend.
During the process, the rear hatch only opens to about 45 degrees, not enough to gain access to the engine bay, should you want to--well, I'm not sure what Gallardo owners do in the engine bay. Look at the engine? Check the oil? That's probably about all the company would tolerate. With the hatch open, there's a loop on the end of a wire latch near the taillights you can pull to open the hatch completely.
Old Jul 20, 2008 | 10:37 AM
vk430gt's Avatar
ahhhh, thanks alot, i needed to know this because im detailing my brothers gallardo spyder on monday and he wanted the engine cleaned. this sorta reminds me of the mercedes hoods, if you want to open them up 90 degrees you have to push some tabs on the hinges.
Old Jul 22, 2008 | 10:52 AM
norcal2's Avatar
norcal2 is infamous around these parts
You are not going to get a lot of access to the engine..not as much as the non spyders have due to the top taking up part of the access...
Old Jul 22, 2008 | 11:23 AM
HZ@RSC's Avatar
HZ@RSC is a splendid one to beholdHZ@RSC is a splendid one to beholdHZ@RSC is a splendid one to beholdHZ@RSC is a splendid one to beholdHZ@RSC is a splendid one to beholdHZ@RSC is a splendid one to beholdHZ@RSC is a splendid one to behold
There is a release pin at the back where the hinge is.. it releases the cover .. just be aware getting it to line up again is a Pain in the ***..
Jul 29, 2019 11:13 AM
turbotuner20v
Sep 11, 2015 12:02 PM
LiquidElephant
Aug 27, 2015 06:17 PM
trek737
Aug 23, 2015 08:12 AM
JMon
Aug 21, 2015 08:20 AM
