Cargraphic Electronic Suspension Lowering Module for Macan In Stock and Ready to Ship
In stock at our shop in AZ and ready to ship out!
Available for all Macan with OEM Air Suspension.
Front axle: -40mm lower (+/- 20mm)
Rear axle: -30mm lower (+/- 20mm)
The electronic lowering module allows a suspension lowering of up to 40mm (+/- 20mm) from the stock setting, which improves the appearance of the vehicle and reduces the centre of gravity for improved handling. The original height adjustment switch and functionality are retained, and many electronic lowering modules feature plug and play installation with no wire cutting / splicing required. The electronic lowering module comes with all necessary mounting components as well as detailed instructions.
All Cargraphic Electronic Suspension lowering modules come standard with a speed controlled deactivation. Over 70 km/h or 44 mph the electronic lowering modul deactivates itself and retains the car to standard ride height for more driving comfort. This function can be also deactivated if not wanted. Also supplied is a switch to turn the lowering on and off if necessary.
gtron
Mar 3, 2020 02:00 PM
