7 speed automatic Problems.....
Old Feb 1, 2008 | 11:51 PM
BAD ASH's Avatar
BAD ASH is infamous around these parts
Has anyone had them, (2006 E350) the Car is 2k away from warranty expiring so I'm taking it to the dealer this coming week.
I do not know if it's because of the cold weather but the it's happened 3 times already. The car seems to be stuck on one gear.
Today I got out of the freeway and will not go down from 6th, not even when I moved the lever manually, I usually live it in drive.
The other day it would not shift above 3rd. Once I shut it off and strt it again it's back to normal, Could it be Electronics or transmission it self.
I don't drive it hard and this is really piscing me off, never had a problem on my old Bimmer.
Old Feb 2, 2008 | 12:02 AM
Tuskir's Avatar
Tuskir has a spectacular aura aboutTuskir has a spectacular aura about
You should definitely take it to the dealer. I've heard of some 7-speed transmissions failing and being replaced under warranty... so if this is the case, you better take care of it ASAP.
Old Feb 2, 2008 | 03:04 AM
Most-Wanted's Avatar
Most-Wanted has a reputation beyond reputeMost-Wanted has a reputation beyond reputeMost-Wanted has a reputation beyond reputeMost-Wanted has a reputation beyond reputeMost-Wanted has a reputation beyond reputeMost-Wanted has a reputation beyond reputeMost-Wanted has a reputation beyond reputeMost-Wanted has a reputation beyond reputeMost-Wanted has a reputation beyond reputeMost-Wanted has a reputation beyond reputeMost-Wanted has a reputation beyond repute
When it does that it will store a code. Mine did it and it was a pressure switch I believe. Just take it in and check for codes.
Old Feb 2, 2008 | 04:43 AM
DrivenAgain's Avatar
Site Sponsor
DrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond repute
I believe 06 was the first year of the 7 speed in the E class and they have been having issues, your dealer should be aware.
Old Feb 2, 2008 | 01:38 PM
BAD ASH's Avatar
Thanks for the replies, hopefully is just a code like MOST-WANTED mentioned.
I'll post what happened next week.
Suds26
Sep 2, 2015 01:33 PM
MC36
Southeast
Sep 1, 2015 06:39 PM
