E55 is a DIFFICULT car to launch
Old Oct 18, 2008 | 09:10 AM
slavik's Avatar
slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !
awesome awesome stuff...cant wait to try out the dyno mode and the ecu reset...see what the animal can do...
Old Oct 18, 2008 | 06:26 PM
slavik's Avatar
what kind of times are people running with stock e55's?
Old Oct 18, 2008 | 09:55 PM
madflava's Avatar
madflava is just really nicemadflava is just really nicemadflava is just really nicemadflava is just really nice
Best times for people are anywhere from high 11's to high 12's, depending on launches, tires, locations, whether etc. I think the best stock is 11.87 on mbworld. Tunes, pulleys and headers are putting them in the mid 11's...11.47 being the record right now.
Old Oct 19, 2008 | 07:10 AM
chidoks's Avatar
chidoks is a jewel in the roughchidoks is a jewel in the roughchidoks is a jewel in the roughchidoks is a jewel in the rough
wow.. these cars are pretty impressive
Old Oct 19, 2008 | 12:28 PM
slavik's Avatar
thanks for the info..... i will see if i can run it this week and come back with some numbers....as a base platform...
Old Oct 19, 2008 | 12:34 PM
madflava's Avatar
Cool, good luck. Just remember, it's all in your launch, so I would practice before you go. If you don't practice, expect to be in the 13's because 516ft/lbs TQ on an automatic tranny will just spin the tires, especially if you are running the stock Contis. But once you hook up, just sit back and enjoy the ride.
Old Oct 19, 2008 | 02:17 PM
slavik's Avatar
I have ps1's on right now... i did the ecu reset last night and noticed the car was a lot more responsive... so i will do the same before i run at the track... and try to raise the car, comfort mode... and 44psi front, 22 psi rear
Old Oct 19, 2008 | 03:14 PM
Zod's Avatar
Zod
Zod is infamous around these parts
tires my friend tires. They make such a huge difference its not even funny
options include
and these are recomended by many
  • Toyo T1r's
  • Nitto invo
  • Mich Ps2
gl
Old Oct 20, 2008 | 04:52 PM
Marcus Frost's Avatar
Marcus Frost has a reputation beyond reputeMarcus Frost has a reputation beyond reputeMarcus Frost has a reputation beyond reputeMarcus Frost has a reputation beyond reputeMarcus Frost has a reputation beyond reputeMarcus Frost has a reputation beyond reputeMarcus Frost has a reputation beyond reputeMarcus Frost has a reputation beyond reputeMarcus Frost has a reputation beyond reputeMarcus Frost has a reputation beyond reputeMarcus Frost has a reputation beyond repute
Dave,
Zod is right. Your difficulty is most likely the result of tires. I find the E55 to be quite an easy car to launch, at least for one with 500lb-ft of torque...
-m
Old Oct 21, 2008 | 08:52 AM
TTony's Avatar
TTony is infamous around these partsTTony is infamous around these parts
I'm looking for an E55 as well. Apparently there is an aftermarket 60/40 LSD that provides much better launches, knocking up to 0.3 sec off the 0-60 time. I think it's by Kleeman.
Old Oct 21, 2008 | 11:12 AM
slavik's Avatar
quaife lSD is most popular for these cars... no?
Old Oct 23, 2008 | 06:36 PM
DFW911T's Avatar
DFW911T is infamous around these partsDFW911T is infamous around these parts
Originally Posted by Max.H
raise the car up all the way, comfort mode, lower rear tires to 21 psi and keep the fronts up to 44psi, take the revs up to 1200-1500 and roll into the throttle taking about a half second, and go wot when you feel the car bite at the top of 1st gear. hope this helps.
the beast is a little tricky to launch well. but when it does it leaves like a scalded cat!
Max is right, the only thing missing is practice, practice, practice.
Old Oct 23, 2008 | 11:10 PM
996TTDave's Avatar
996TTDave has a spectacular aura about996TTDave has a spectacular aura about996TTDave has a spectacular aura about
[edited_ ]
Old Oct 24, 2008 | 05:32 AM
slavik's Avatar
ESP ON i would assume...
Old Oct 24, 2008 | 01:14 PM
DFW911T's Avatar
Originally Posted by 996TTDave
Is ESP to be on or off?
My best times have been ESP on.
