CLK Black - battery charger connectoin question..
Old Apr 1, 2009 | 06:24 PM
tssci's Avatar
tssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to behold
There is a square RED plastic cap in the engine bay marked with the + positive sign and a large spade connector beneath....can anyone confirm that this can be used to connect a battery charger to, i.e. battery tender, CTEK, etc? I ask because there is a battery charger connection in the trunk, but obviously configured to only accept a MB charger unless I do a 'cut and splice' which I'd rather not do. Thanks!
Old Apr 1, 2009 | 07:27 PM
JJayB's Avatar
JJayB is infamous around these parts
tssci,
Since you can only jump start from the contacts located in the engine compartment this is where you would connect a battery charger. The manual suggests that you not use the maintenance interface if you have a fully discharged battery but remove the battery for charging. Are you hooking up a tender or charger?
Jimmy
Old Apr 2, 2009 | 07:33 AM
tssci's Avatar
CLK Black...battery tender..
Jimmy - thanks for your prompt and informative response. Yes, I simply want to connect a Battery Tender or CTEK unit - both are maintenance/trickle chargers. It sounds like you agree that the engine connection would be OK - correct?
Old Apr 2, 2009 | 09:41 AM
JJayB's Avatar
Steve,
PM.
Old Apr 3, 2009 | 12:19 AM
ET550's Avatar
ET550 is infamous around these parts
I don't believe the connection in the trunk is only for an MB charger. A number of battery chargers come with optional connectors to match the ones in the trunk.
cnebrask
Oct 3, 2024 08:19 PM
osj911
Aug 26, 2015 06:41 PM
DSCOFF
Aug 23, 2015 01:22 PM
