Evosport | New Lightweight 2-Piece Front & Rear Rotors for 63 AMG
Old Feb 22, 2010 | 11:30 PM
simon @ evosport's Avatar
simon @ evosport is infamous around these partssimon @ evosport is infamous around these parts
UP TO 40-LBS WEIGHT SAVINGS!
Available for: C63 AMG, CLK63 AMG, CLK63 AMG Black Series, E63 AMG (W211 and W212), CLS63 AMG, SL63 AMG
Designed as a direct brake rotor replacement for the OE 1-piece or 2-piece (not 390mm) brake rotors (front and rear). No modifications are necessary. The Evosport rotors will bolt directly to the car and work with OE AMG brake calipers. Not only will the upgraded multi-piece "floating" rotor design help mitigate brake fade, but are lighter than stock and reduce unsprung weight by up to 40-lbs. on all four corners! Note: 26-lbs weight savings on vehicles equipped with 2-piece OE front rotors. This means better acceleration, braking and cornering. In addition, you get to maintain the AMG calipers without going to a more expensive solution that requires replacing them.
Drilled and slotted to match the OE rotors, hats are lightweight aluminum and hard anodized. And unlike the stock rotors that only vent correct on one side (or have universal venting), the Evosport rotors have a Right and Left application for proper venting of the disc and chaneling of airflow.
Benefits:
  • Direct bolt-on design requires no modification
  • Works with OE AMG calipers
  • Lightweight design (up to 40-lbs unsprung weight savings over stock! 26-lbs weight savings on vehicles equipped with 2-piece OE front rotors.)
  • Aluminum hat, hard anodized (Black)
  • Better value and cost of ownership over very $$ OE rotors!
  • Unique Left/Right application for proper venting/airflow (unlike OE)
  • Replaceable discs and hardware
  • Better heat dissipation and less brake fade
  • Improved acceleration, braking and cornering with less unsprung weight!
Includes Front and Rear rotors with black anodized hats (Front or Rear pairs can also be purchased separately). For more information or to order, click below:Please feel free to call or email us with any questions.
Anthracite anodized hats shown below. Actual rotors have black anodize:
Evosport 2-Piece Rotor Installed on SL63 AMG (Note: Right-Side Rotor Shown):
Old Feb 23, 2010 | 08:39 PM
NWturbo's Avatar
NWturbo has a reputation beyond reputeNWturbo has a reputation beyond reputeNWturbo has a reputation beyond reputeNWturbo has a reputation beyond reputeNWturbo has a reputation beyond reputeNWturbo has a reputation beyond reputeNWturbo has a reputation beyond reputeNWturbo has a reputation beyond reputeNWturbo has a reputation beyond reputeNWturbo has a reputation beyond reputeNWturbo has a reputation beyond repute
R63/ml63
Hi
Will these fit, or do you have an application for the R63/ML63??
Thanks in advance.
Old Feb 23, 2010 | 09:08 PM
Originally Posted by NWturbo
Hi
Thanks in advance.
Unfortunately no, the ML and R-Class have very different brake setups. We don't have an application for the ML or R, other than going to a Brembo or Rotora upgraded system as we just did on an ML63.
Old Feb 23, 2010 | 10:05 PM
NWturbo's Avatar
OK. Thanks.
Thanks for the response Simon.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
