Vaeth C63 AMG Products from FierceSpeed
Subscribe
Feb 12, 2011 | 03:15 PM
Hello everyone. I'd like to introduce our Vaeth C63 AMG products to the 6speed community!
Vaeth has a multitude of products available for Mercedes-Benz ranging from aerodynamics to brakes to engine upgrades and more. Below is a guide of what's available for the C63 AMG from Vaeth.
Feel free to contact us with questions and applications.
Vaeth Performance Packages (Resulting power from 518hp to 572hp, contact us for specifics!)
High-Grade Steel Catalytic Converters (EXPORT)
Silencer System
made of VA High-Grade Steel
Silencer System made of Titanium
VÄTH Forged Rim
Three-part forged rim with titanium colored spokes
- 8.5 J x 20 Front axle
- 9.0 J x 20 Front axle
- 9.5 J x 20 Rear axle
- 10.0 J x 20 Rear axle
- 10.5 J x 20 Rear axle
Carbon Air Outlet
Carbon Hood
Rear Diffusor Fins
Consisting of high class carbon.
Only in conjuction with Sport-Package AMG (Code 950).
Rear Diffusor
Consisting of high class carbon. With fins and larger underbody.
For limousines and station-wagons.
Additional Rear Lip (for trunk)
For limousines
Carbon Rear Lip (for trunk)
Consisting of high class carbon. For limousines
Fender
Consisting of glass fiber composite material. Sporty premium design. Left and right side. Primed.
Radiator Grill without Mercedes Emblem.
Primed.
Carbon Front Spoiler
For optimization for aerodynamics, less ascending force. Sporty, noble appearance. Consisting of high class carbon.
Carbon Interior
Classic design of carbon in black for interior refinement. Highest processing precision and perfect fitting. Handmade in Germany. In exchange for your original parts. Additional charge for colored or multicolored
carbon.
Consisting of:
- Climate visor
- Ashtray cover in front
- Gear shifting gate
- Gear lever ****
- Door visors
- Seat adjustment on the right, on the left
Track Widening Spacers
10 mm/each site resp. 20 mm/each axle front
10 mm/each site resp. 20 mm/each axle rear
15 mm/each site resp. 30 mm/each axle front
15 mm/each site resp. 30 mm/each axle rear
Track Widening Spacers 20 mm/each site resp. 40 mm/each axle rear
twin-screwed, original wheel bolts can be used.
Lowering
30mm with lowering spring set. Sporty-save road ability and still comfortable
Complete Chassis
About 20-65mm lowering by spring set and infinitely hardness and height adjustable dampers.
Optimal and save handling, still comfortable. For road and race track.
Brake-Optimization
Brake line kit and racing brake fluid Castrol SRF.
High-Performance Brake System for C 63 AMG
378mm brake disc at the front axle with 6-piston brake caliper and brake lining
set as well as racing brake fluid Castrol SRF and brake line kit.
Attention: At least 19" inch tires necessary at the front axle.
Limited-slip differential
For all C-Classes with automatic transmission. Improved traction and acceleration, improved cornering ability. For road and race track.
For all C-Classes with manual transmission. Improved traction and acceleration, improved cornering ability. For road and race track.
Fuel Cooler
Cooler fuel has a higher density. Efficiency improves clearly. Much better combustion guarantees excellent exhaust values, less fuel consumption, lower temperature in combustion chamber and more power. For highly required engines and for all those customers, who want to foster their VÄTH- or Mercedes-engine exceedingly. Including tubes and fittings.
Engine Oil Cooling System
Transmission Oil Cooling System
Please visit our website @ Http://www.FierceSpeed.com for information and pricing.
Reply
Feb 19, 2011 | 08:47 PM
We currently are offering free shipping until the 28th of this month.
Reply
Subscribe
