Why does my car run out of breathe? Help
Old Oct 22, 2011 | 10:45 AM
rrdralli's Avatar
rrdralli is infamous around these parts
I have a 2003 SL 55 with 38,000kms on it. everything seems good and engine is strong except sometimes when I punch the throttle it pushes hard and then monements later the throttle doesn't rev up like normal. ( slow rev, no power but rev still goes up slowly) feels like the car lost its breathe or the engine is unconscious. but sometimes couples seconds later it will regain consciousness and lots of power. anyone knows why? coils? Airmass?
Old Oct 22, 2011 | 11:24 AM
e46m3smg's Avatar
e46m3smg is infamous around these partse46m3smg is infamous around these parts
You should get someone with a STAR unit to check it out.
Old Oct 22, 2011 | 07:08 PM
GENTANI's Avatar
GENTANI is infamous around these parts
cooling pump then heatsoaked?
Old Oct 22, 2011 | 10:03 PM
EV0LVE's Avatar
EV0LVE is a jewel in the roughEV0LVE is a jewel in the roughEV0LVE is a jewel in the rough
slipping tranny?
Old Oct 23, 2011 | 06:48 AM
BB Supra's Avatar
BB Supra is infamous around these parts
replace your intercooler pump.
Old Oct 23, 2011 | 06:44 PM
smalone01's Avatar
smalone01 is infamous around these parts
I would check the intercooler pump as well but you really need to pull codes and go from there.
Old Oct 23, 2011 | 09:00 PM
cig1's Avatar
Wannabe
cig1 is infamous around these parts
Check the coils ... one or two bad ones could spoil your day
g
Old Nov 29, 2011 | 10:03 PM
V8HAHA's Avatar
V8HAHA is infamous around these parts
Its definitely the intercooler pump. Its lagging b/c of heat soak. Get the Johnson CM30 intercooler pump as a replacement.
Old Nov 30, 2011 | 12:07 PM
AMG3.2's Avatar
AMG3.2 is infamous around these parts
+1 Look into Johnson Cooling Pumps. I'm not sure about the SL55, but my C32's intercooler pump goes bad every 40k Miles or so. It's about $200 and can be installed yourself fairly easily.
Old Nov 30, 2011 | 12:55 PM
rrdralli's Avatar
thanks guys, will try replacing the pump see what the results are. I'm new with the AMG's not too familiar with the engine. does anyone have any install guides for the pump or where its located?
Old Jan 10, 2012 | 10:32 AM
rrdralli's Avatar
I finally had time to bring my car to the shop to install the Johnson CM 30 pump. But after getting the car back I noticed the car is EVEN WORSE NOW.......the car has noticeably loss power at the throttle. The OEM pump before worked better just with heat soak once in a while..
I'm thinking this has got to be something the shop did wrong in the install. Reversed polarity on the pump or water lines? thinking it can't be the pump causing the problem. dunno why but will bring the car back to the shop tomorrow.
Old Jan 10, 2012 | 11:15 AM
the head's Avatar
the head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the rough
Yep - it's a pain to get all of the air out of the system when replacing the pump. I run a Meziere and wired it in myself, but it took a lot of "burping" to get the air out.
Old Jan 10, 2012 | 12:11 PM
rrdralli's Avatar
Thanks for the info The Head, didn't come across my mind but now I'm thinking the shop didn;t bleed the system. Any procedures on doing it properly? I tried to look for the bleed valve but can't locate it.
COBB Tuning
Jan 1, 2025 09:02 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Fabspeed Motorsport
Aug 26, 2015 11:15 AM
