New Product-W212 E63 Pre Face Lift Carbon Aero Parts Sedan/Wagon
Old May 20, 2014 | 02:30 PM
Mike@Renntech's Avatar
Mike@Renntech is infamous around these parts
We are happy to release our Carbon Fiber Aero Products for the Pre Face Lift W212 E63 Sedan and Wagon. We have the front splitter and rear diffuser in stock. The deck lid spoiler for the sedan will be coming in the next couple months. Like all RENNtech aero parts they are designed 100% in house and are built using Pre Preg Carbon Fiber technology that gives a OEM like fitment and durability second to none. Please PM me with any questions or to place an order.
What exactly is prepreg carbon fiber?
  • Prepreg is widely known as the finest process in carbon fiber manufacturing and has been used for aerospace and military applications because of its superior consistency in weight, thickness, fitment, resin, carbon layout, and overall quality.
  • Lower cost carbon fiber uses a wet-layup method which results in components of inferior, strength, appearance and overall quality. To create prepreg fiber is pre-impregnated (hence the name) with resin at a production facility, rolled on spools, and frozen to prevent the resin from curing prematurely. This material is then cut and hand laid into a mold to the proper thickness and cured at strictly controlled temperatures. This process creates a laminate with a precisely controlled resin volume and in turn is 20-30% stiffer and stronger than an equivalent thickness wet laminate process.
  • The pre-impregnated (prepreg) fiber method creates stiffer, stronger laminates with controllable, predictable results and the result is a consistent, tight fiber weave which not only looks amazing, but adds strength. This ensures our customers receive components which not only look good on the vehicle standing still, but won’t crack, warp, fall off or fade when mounted to the exterior of their vehicle after six months or while driving at high speed.
ID:	376744   Click image for larger version
ID:	376745   Click image for larger version
ID:	376746   Click image for larger version
ID:	376747   Click image for larger version
ID:	376749   Click image for larger version
ID:	376750   Click image for larger version
ID:	376751   Click image for larger version
ID:	376752   Click image for larger version
ID:	376754   Click image for larger version
ID:	376755   Click image for larger version
ID:	376756   Click image for larger version
ID:	376757   Click image for larger version
ID:	376759   Click image for larger version
ID:	376760   Click image for larger version
ID:	376761   Click image for larger version
ID:	376762   Click image for larger version
ID:	376764   Click image for larger version
ID:	376765   Click image for larger version
ID:	376766   Click image for larger version
Old May 20, 2014 | 02:51 PM
Here are some of the wagon. This customer painted the carbon black for a different look.
ID:	376771   Click image for larger version
ID:	376772   Click image for larger version
