Weekend Projects....
OK so since it was only about 110 today I finsihed half of what I set out to do...
First project was install Euro Comand. I used some installation insturctions found on this board... First Removed ash tray. http://gallery.rennlist.com/albums/2...2274.sized.jpg Then lift up on the front of the wood panel around gear lever, once that is out you can see two hex screws that hold the CD changer in place. Remove changer & unplug wire connectors. http://gallery.rennlist.com/albums/2...2275.sized.jpg After CD changer is out you will see two more size 20 Hex screws, unscrew these until they stop turning, they will not fall out. Once those are loose the Head unit will slide right out. Unplug the two connectors and remove. http://gallery.rennlist.com/albums/2...2276.sized.jpg Re-install everything back and your good to go.. I also had the code that enabled the in motion viewing. This worked like a charm. The picture is great!! and the sound is even better!! http://gallery.rennlist.com/albums/2...2282.sized.jpg Ok next project was Renntech Steering Wheel. To remove the steering wheel you will need a size 30 Hex head, I have one that has a socked end which was needed because you have a short area to work with. Once you remove the two screws, one on each side, the airbag becomes loose and removable. At this time is when you should disconnect the battery. There are two connectors orange & green with little tabs that lift off, to remove the connectors. http://gallery.rennlist.com/albums/2...2291.sized.jpg To remove the wheel you will need a large allan, preferablly one with a socked end so you can torque it down correctly. Be sure you have the wheel in a perfect straight position so when you put the new one on its centered correctly. I then removed the shifter buttons on the back of the stock wheel, along with the silver bracked you see above. This is what the shifter wires plug into, as well as the buttons on the airbag for the stereo and computer. http://gallery.rennlist.com/albums/2...2292.sized.jpg sorry its blurry, but you can see how thick the Renntech wheel is. http://gallery.rennlist.com/albums/2...2293.sized.jpg http://gallery.rennlist.com/albums/2...2294.sized.jpg And here is the before and after.. http://gallery.rennlist.com/albums/2...2178.sized.jpg http://gallery.rennlist.com/albums/2...2298.sized.jpg |
Very impressive, nice work. Now when do we hire you out and make some loot!!!!;)
J.Wade |
Very nice Kevin,, youre the DIY master:D
Kev is the MOD KING!
Nice mods,
Thanks guys! :)
Very cool!
Well done...that new one is simply better! ;)
the renntech steering wheel looks so much better IMO
Kevin:
what does the Euro Command do? I appears you can play movies in motion? my father has a cl55, is this adaptable to his ride? thanks. |
Originally Posted by JWGT2
Kevin:
what does the Euro Command do? I appears you can play movies in motion? my father has a cl55, is this adaptable to his ride? thanks. Yes you can watch DVD's on the NAV screen, I'm not sure about the CL55, I believe there is some sort of filter on there can be removed. Check out mbworld.org the CL board will have some more info. Are you going to make it to Concorso next month? |
