Slik Pro 340DX Tripod (Titanium) w/ 3Way Pan/Tilt Head (Quick Release)
Old Mar 16, 2007 | 01:48 AM
1QUIK993's Avatar
1QUIK993 is infamous around these parts
Brand new, only taken out of the box to take pics. I am asking $90 shipped to the 48 states.
B&H usually is the most reliable place with one of the best prices, theirs is $99.95 + shipping. Link to the tripod at B&H: http://www.bhphotovideo.com/bnh/cont...ughType=search
The Slik Pro 340DX is a complete all-metal tripod setup that's effective for lightweight travel duty when one desires a professional feel. The A.M.T. super titanium alloy legs make the Pro 340DX tripod rock steady yet lighter than it looks. The A. M. T. alloy has a 40% greater strength to weight ratio than standard aluminum, meaning the legs are lighter weight yet stronger than the standard metal used in most of today's tripods.
Key Features
•Speed Release Lock levers allow for fast set up
•3-Position leg locks allow for leg openings of independent angles
•Rubber leg tips for maximum traction outdoors and protection to surface indoors
•Foam covered upper leg sections for easy handling in extreme hot or cold weather
•Maximum upper leg diameter of 27mm
SPECIFICATIONS:
Maximum Height
57.9" (147 cm)
Maximum Height w/o Column Extended
45.7" (116 cm)
Minimum Height
18.1" (46 cm)
Folded Length
19.3" (49 cm)
Load Capacity
11 lb (5 kg)
Leg Sections
Leg Lock Type
Flip lever
Independent Leg Spread
Yes
Center Column Sections
Center Column Type
Sliding
Center Brace
No
Spiked Feet
No
Head Type
3-way pan/tilt
Head Mount Thread Size
3/8 & 1/4"
Weight
3.5 lb (1.580 kg)
Old Mar 17, 2007 | 11:50 PM
1QUIK993's Avatar
SOLD!
too short
HotRod
Sep 10, 2015 07:17 PM
akbjr
Sep 7, 2015 07:40 AM
pwdrhound
Aug 20, 2015 05:54 AM
