Wood fire pit on Azek deck.....floor protection?
Old May 15, 2011 | 10:44 AM
boochook's Avatar
boochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond repute
Ok guys,
Summer is almost here. We just had our deck built by our general contractor, who I highly recommend using Azek decking. Got a fire pit lounge set coming in. I know you can use certain pads to protect the floor from radiant heat, so wanted to check what people were using or recommend. I am considering this but want to confirm if you guys think it is worth it....
http://www.amazon.com/DeckProtect-Fi...5476857&sr=8-2
Thanks.
Old May 15, 2011 | 09:05 PM
Exlondoner's Avatar
Exlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud of
Berk I was also in the same position as you a few years ago but decided against placing a fire pit table on our deck, there I built an additional patio out if gravel for the pit.
If you really set on placing the pit on your deck then perhaps you could do something like this:
1. Lay down some 12"x12" pavers with perhaps a border
2. Fill it with sand which is a fire retardant and set the pit on that.
Goodluck with whatever you decide and be safe.
Old May 15, 2011 | 09:37 PM
tonka858's Avatar
tonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud of
Old May 16, 2011 | 05:59 AM
deckman's Avatar
I don't know if I would build a pit into a wood deck. It's probably better to do gas or buy a portable one.
We did a stone patio at the walk out level with a masonry pit. That doesn't work for everyone though.
Old May 16, 2011 | 02:37 PM
boochook's Avatar
Thanks guys...... Definitely will take in to consideration what everyone has said.
Hey John - I didn't build a pit in to the deck, rather, got a table that is also a firepit. How have you been man?
BLKMGK
May 31, 2016 04:32 AM
FUTURESTAR
Sep 23, 2015 05:42 PM
JWrightPNH
Sep 14, 2015 01:15 PM
