996 Turbo Going Under the Knife. Suggestions?
Old Sep 3, 2012 | 12:49 PM
Scott in SS MD's Avatar
Scott in SS MD has a brilliant futureScott in SS MD has a brilliant futureScott in SS MD has a brilliant futureScott in SS MD has a brilliant futureScott in SS MD has a brilliant futureScott in SS MD has a brilliant futureScott in SS MD has a brilliant futureScott in SS MD has a brilliant futureScott in SS MD has a brilliant futureScott in SS MD has a brilliant futureScott in SS MD has a brilliant future
Taking her in to TPC tomorrow for sway bars, track/street alignment, oil change, change oil pressure sender. Anyone have any ideas as to what else I should knock out while in the shop? Just clocked 33k miles. Going with sway bars only, but was reading up on their Stage 1 & 2 suspension setups and must say, they sound appealing.
My track day average per year has gone down to 2/year as DE events. As much as I love the track events, time and money hold me back from what I really want to accomplish at the track. For a weekend track and street warrior, would you stick with sway bars and be done with it? Don't want to break the bank, nor do I want a rickety ride on the streets when not on track.
Scott
Old Sep 4, 2012 | 05:52 AM
Misanors4's Avatar
Misanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant future
You can drive mine with Motons, but I'm afraid that won't make your decision making any easier
Old Sep 5, 2012 | 03:52 PM
TMC CL65's Avatar
TMC CL65 is a jewel in the roughTMC CL65 is a jewel in the roughTMC CL65 is a jewel in the rough
How about some K24/18G's?
Old Sep 6, 2012 | 11:56 PM
sunir's Avatar
You don't need any of that on track Scott ... Your car is plenty ready. Spend your money on a good set of tires, brake pads and a castrol srf brake fluid flush, get an alignment done and your good to go. Save your money and get more seat time out of it.
Old Sep 8, 2012 | 04:56 PM
911stripper's Avatar
911stripper has a spectacular aura about911stripper has a spectacular aura about
drop links and toe links..tell tom to give you some negative camber too. all of that with your new sways and you wont recognize your car!
you will thank me later
Old Sep 26, 2012 | 03:34 PM
Thanks for all the suggestions. Going with adjustable toe links and sway bars. Some general maintenance of oil, fluids and to tighten the oil pressure sending wires. Should be ready tomorrow, just in time for Saturday's fun run.
Will be looking to swap or sell my HRE's so I can put some wheels on with a tighter offset. Need to tuck it in about an extra inch so I don't rub the fenders with phatter tires like I presently have. The Hankook's didn't rub but these expensive Potenza's are slightly taller so I will get a slight rub on my already rolled fenders.
See you guys Saturday if the weather holds up.
Old Sep 26, 2012 | 06:28 PM
markar's Avatar
markar is a name known to allmarkar is a name known to allmarkar is a name known to allmarkar is a name known to allmarkar is a name known to allmarkar is a name known to all
Scott did you have stainless steel break lines? TPC put on my car big different ...
Old Sep 26, 2012 | 06:47 PM
No, just did brakes w/ ATSpeed last Spring. Maybe next round.
Old Oct 18, 2012 | 11:11 AM
Suspension feels tight but my ride height is still off by 1/2" on right rear and my wheelbase center to center is still off also by 1/2" from driver side. Says it could be the older shocks, something bent, etc. since they didn't look for the problem then, I would like to go elsewhere to investigate this issue since they want to charge to look at it again. Anyone have a shop they recommend for this specific type of work?
Old Oct 18, 2012 | 12:20 PM
deckman's Avatar
+1 on Scott's question. I'd love to know of a decent local shop that's good with suspension.
Old Oct 18, 2012 | 01:48 PM
Misanors4's Avatar
What kind of HREs do you have?
Old Oct 18, 2012 | 02:07 PM
7 year old 847R's. Still in great shape.
Old Oct 19, 2012 | 09:39 PM
Zahjah's Avatar
Zahjah has a spectacular aura aboutZahjah has a spectacular aura about
SSI towson speak with sloan. 410 668 1100
PelicanParts.com
996 Vendor Classifieds
Aug 20, 2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:45 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
