Any shop in NOVA to take a Mini for mods
Have an 09 cooper s, the damn thing has no temp gauges in it and is driving me insane. Also want other work done.
Looking for a shop that specializes in Minis or at least has some experience/knowledge working on them.
Definitely avoiding any shops in MD, just NOVA plz.
Thanks.
Thanks.
The aftermarket parts for strictly bolt ons for the MCS is typical CAI, DP/exhaust, and bigger intercooler. Sucks that there isnt the mod following that the early R53's had.
The IC and boost tubes is quick and probably the most bang for your buck. The exhaust is the next but getting pricey. To go all in the exhaust with a strait downpipe and exhaust will throw CEL but thats about it. I have thrown a few emissions lights here and there by just driving like a A-hole.
Getting more hard parts then the bolt on still isnt there. They have started to get into PnP heads. Place in FL does it. Big money. Also heard of people putting GT2RS turbos for some good hp but there is a lack of tuners.
Thanks Jay
First things is water and oil temp gauges, then boost gauge.
Someone slammed into the side of me on the NJ turnpike and the car has a slight wobble in the steering wheel at around 50mph, not sure if it's alignment related.
Could be alignment or a control arm problem, or maybe as simple as losing a wheel weight. Good luck!
Thanks.
Thanks.
Hey I have 09 MCS also, and recently did AEM intake, doing the coilovers and swaybar this Saturday, next Alta FMIC than full exhaust.
in regards to temps, oil, boost etc check out Scan Gauge II, many mini guys are using it and it's on my list to get also. Way Motor Works have them pre-updated for minis and you can do so many things w/it, clearing cell etc..
http://www.waymotorworks.com/
+1 on the ALTA FMIC. I had to trim some of the inside of my bumper to fit. The boost tubes are also a good upgrade when doing the FMIC. Its dwarfs the OEM unit. You going to keep the cats or go strait DP? Can the SG II clear/reset maintenance codes as well?
I forgot I did get the hot side pipe to go with ALTA FMIC, I am also looking at Evolve full system with de-cat DP and exhaust. What I've read on the NM is it can clear or reset codes as well.
