Mini Cooper Vendor Classifieds vendor classified area...do not post here unless you are a forum sponsor
:: ECS Tuning :: MINI R61 Paceman GEOMET® Brake Rotors
Old Aug 18, 2014 | 03:36 PM
ECS Tuning - BMW's Avatar
ECS GEOMET® premium brake rotors start with quality materials and precision ECS machining. That would be enough for most of us, but it is only the beginning.
To prevent brake pad deposits for better braking, select a slotted ECS GEOMET® rotor. Slotting cleans the pads by moving water, gasses, and contaminants away from the pad/rotor contact surface.
To prevent rust pitting and corrosion damage, ECS GEOMET® rotors are sprayed with a special water-based solution, then heated to cure the coating and remove all oil residue remaining from the manufacturing process.
Prevent rust pitting and corrosion damage.
Fits:
R61 MINI Paceman Base (2013+)
Click HERE for the ECS Geomets
ECS Tuning - VW
Aug 24, 2015 01:51 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
