Mini Cooper Austin and Morris Mini talk, and the 2001-2006 Mini and Mini S, 2007 to present Mini and Mini S
Need mini help
Old Jan 5, 2009 | 10:56 AM
henryr's Avatar
henryr is infamous around these partshenryr is infamous around these parts
Need mini help
hey guys,
i am either looking for a used mini that has had some mods which it would make it track worthy for track day and street usage or i'd be looking to buy a used car and do the mods myself.
specifically, what mods (such as suspension / brakes) would i want to make. actual products rec's please.
Old Jan 5, 2009 | 11:00 AM
henryr's Avatar
what year / options would make a good base car ? not looking to break the bank here. just a clean driver and something thrash at the track
Old Jan 6, 2009 | 07:07 PM
healey67's Avatar
healey67 is infamous around these parts
Check out sunshineminis.org and look in the MINI classifieds. There is a Chili Red MINI R53 that is up for sale with a FEW mods on it.
Old Mar 30, 2009 | 10:54 PM
dynamicss's Avatar
dynamicss is infamous around these partsdynamicss is infamous around these partsdynamicss is infamous around these partsdynamicss is infamous around these partsdynamicss is infamous around these partsdynamicss is infamous around these parts
you could go with a decent set of H&R RSS coilovers (not as expensive as the others), with H-sport 27mm front (don't really need it, unless you really and truly track the car) and 25mm rear sway bars (again 22mm is just fine unless you really and truely track the car.) front and rear stress bars are all the mods you pretty much need for the suspension. You could also get camber plates and control arms and a-arms... but they are all useless.... I've had lots of professional help with mine.
Old Apr 2, 2009 | 07:34 PM
beaner's Avatar
beaner is infamous around these parts
i tracked my daily driver quite a bit before deciding to make it a track only toy. i would have to disagree with the above post. any increase in front anti-sway bars is not a good idea on a car that inherently understeers from the factory. front and rear stress bars do next to nothing for the handling (especially the rears which don't tie into any suspension pickup points). camber plates are a MUST have item. i would go through a set of tires in two short sessions without them. adjustable lower rear control arms are required only if the car has been lowered over an inch with coilovers or springs. rear camber becomes excessive when lowered. i don't know who is giving you professional advice, but it goes against what i (and my track-rat buddies) have learned on the track, in depth conversations with many MINI racers and information read on other forums. my .02
to answer the op....the car is fun and fast from the factory. upgraded brake fluid, track only brake pads, more front camber will help you hustle it around the track better. r-comps will become necessary when you get faster and get tired or replacing your street tires. an 15% pulley will add some power, but the MINI still isn't a powerhouse. we catch them in the twisty bits and under braking.
ECS Tuning - BMW
Oct 1, 2015 01:35 PM
ECS Tuning - BMW
Oct 1, 2015 01:29 PM
ECS Tuning - BMW
Sep 30, 2015 06:18 AM
ECS Tuning - BMW
Sep 29, 2015 01:18 PM
ECS Tuning - BMW
Sep 25, 2015 12:47 PM
