Mini Cooper Austin and Morris Mini talk, and the 2001-2006 Mini and Mini S, 2007 to present Mini and Mini S
Supension Upgrade Question
Old Feb 18, 2009 | 06:52 AM
flynduc's Avatar
flynduc is infamous around these parts
What is a good supsension upgrade for MINI?
Does the JCW kit reduce ride height? OR is it better to go with coilover kits by KONI?
THANKS
Old Mar 3, 2009 | 11:15 AM
bullitt44's Avatar
bullitt44 is infamous around these partsbullitt44 is infamous around these parts
I am going to add a set of Koni yellows, H&R Spring and a rear sway bar before it hits the track.
The JCW kit lowers the car a little under an inch, if you are going for looks it is not the right choice. It is a very nice factory set up and definitly better than the stock setup. Koni Coilovers will let you dial in your wants, just be sure to have it professionally setup and corner balanced.
Old Mar 10, 2009 | 10:17 AM
RepoMan's Avatar
RepoMan is infamous around these parts
+1^ Good advice there.
Jul 29, 2019 11:13 AM
vr6tee
Aug 29, 2015 03:52 AM
tkeck3
Aug 25, 2015 02:52 PM
Aug 19, 2015 06:35 PM
