Mini Cooper Austin and Morris Mini talk, and the 2001-2006 Mini and Mini S, 2007 to present Mini and Mini S
08 mini cooper power steering issue
Old May 12, 2013 | 10:06 AM
turbosonoma's Avatar
turbosonoma is infamous around these parts
the power steering motor on my rack had an issue so i changed it, now it is working sporadically and not properly, does it need to be programmed at the dealer?
Old May 14, 2013 | 08:09 AM
ECS Tuning - BMW's Avatar
Whats chassis do have? Sounds like you are talking about a Gen 1 R52 2008 Convertible since it has the separate motor from the rack.
Gen 2 R56 + have the power steering rack with integrated motor.
Old May 28, 2013 | 10:04 AM
It's a gen two.
Old May 28, 2013 | 10:55 AM
The whole unit comes with the electronic motor attached. And should not require programming.
http://www.ecstuning.com/Search/32106856876KT/
I would check the electrical connections at the unit itself. And also check you battery voltage , when they battery is on its way out , there can be intermediate functions in the electrical system.
Do you have a steering wheel symbol with exclamation point showing up on the tach display?
Old May 28, 2013 | 10:31 PM
Yes the exclamation mark is there. And the dealer says the rack/motor is shot. They wanted like 2500 so I got a used complete unit. But I'm wondering if it will need to be programmed at the dealer, maybe steering angle sensor reset or something after I change it. Any idea?
Old May 29, 2013 | 09:15 AM
Is the exclamation point still there? I did not know you had a used unit.
On using a used unit, I don't have much info on that , I know new ones are replaceable without reprogram. All I could figure is that it has stored points in the steering angle sensor. I would also check those connections, its possible there is a problem there since its on and off.
Might be worth it now since you have a used one to hook it up and see what it reads.
ECS Tuning - BMW
Aug 21, 2015 01:47 PM
ECS Tuning - BMW
Aug 19, 2015 01:35 PM
ECS Tuning - BMW
Aug 19, 2015 01:22 PM
ECS Tuning - BMW
Aug 19, 2015 11:19 AM
ECS Tuning - BMW
Aug 19, 2015 09:23 AM
