Mini Cooper Austin and Morris Mini talk, and the 2001-2006 Mini and Mini S, 2007 to present Mini and Mini S
Cooper S wiring problem?
Old Aug 14, 2013 | 07:55 PM
Ryan...'s Avatar
Ryan... is infamous around these parts
The board on the left is from the driver's side, right is passenger side. Despite the crappy looking brake light/running light bulb on the left, it works fine. (According to manual, top lights not in use on either side)
The issue is this: on the right, the running light does not work. Brake light and turn signals work fine. However, when you plug the right board in on the left side the running light works.
When you switch the left board to the right, same thing; no running light but everything else works fine.
Anybody know where to start digging to fix the problem? It's not a faulty board like I guessed, nor an issue with the bulbs...
Any help is appreciated!
Old Aug 16, 2013 | 08:30 AM
ECS Tuning - BMW's Avatar
Looks like you have the 2002 -7/2004 light taillight bracket.
What year is your MINI ?
Did you check the contacts at the base on the wiring harness side. Sounds like a pin is not making contact on the right hand wire harness. I would make sure all pins are ok. Sometimes moisture can get back there in the corner.
Here is the socket board just to verify part number: MINI part # 63216916395 #7 in the diagram
http://www.ecstuning.com/Search/SiteSearch/63216916395/
Old Aug 16, 2013 | 08:32 AM
Ryan...'s Avatar
Thanks for the response, it is a 2002 Cooper S.
I'll check the pins, I only gave them a passing glance.
Old Aug 16, 2013 | 08:37 AM
Great,
Yea sounds like no pin contact on that side since its the same with both panels.
ECS Tuning - BMW
Sep 1, 2015 08:10 AM
ECS Tuning - BMW
Aug 28, 2015 02:04 PM
ECS Tuning - BMW
Aug 28, 2015 01:57 PM
PelicanParts.com
Aug 20, 2015 04:01 PM
ECS Tuning - BMW
Aug 19, 2015 01:22 PM
