New Member Introductions New here? Introduce yourself to the 6SpeedOnline Community and show us your ride!
Coolant leak
Old Sep 7, 2018 | 07:45 AM
Porsche 997.1 TT's Avatar
Porsche 997.1 TT is infamous around these parts
Coolant leak
Hello dears
I'm facing coolant leak issue
I need your advise
my car is 997.1 TT 2007
the car doesn't leak unless if I drive the car hard and put the car at Parking and turn the engine off leak appears and it's very noticeable some times small amount of water sometimes a huge
Old Sep 7, 2018 | 11:27 AM
Originally Posted by Porsche 997.1 TT
Hello dears
I need your advise
Old Sep 7, 2018 | 11:28 AM
I'm really not sure from where is the leak
I have replaced the pipe and issue still there
Old Sep 8, 2018 | 09:04 AM
NJB997's Avatar
NJB997 is infamous around these parts
If you research coolant leaks on 997.1 engines and 996 too....you will find many posts on this issue. I just had my engine out 07 TT with 31k miles to address (have pinned) slipped cam shaft sleeves under an extended warranty, and while the motor was down had all the coolant fittings welded, put in a sharkwerks kit, and replaced hoses, seals, o-rings and water pump. The coolant system fix is about a $5+k job at a good independent shop. The specific source of your leak could be a hose or connection, but what you described is probably the bad OE glue failing at a fitting somewhere out of sight and inaccessibly located on top of the engine. Good luck!
Dale D
Cayenne 955/957
19
Aug 12, 2018 06:45 AM
newporsche
Jun 29, 2018 03:46 PM
JustinCase
Jan 3, 2016 03:39 PM
MadWhip
Feb 21, 2015 05:23 PM
