ALPHA R35 GT-R Carbon Ceramic Brake Upgrade
Subscribe
Aug 6, 2013 | 01:16 PM
Alpha R35 GT-R Carbon Ceramic Brake Package
The Alpha R35 GT-R Carbon Ceramic Brake Package shaves 60lbs of rotating mass AND improves the braking capabilities of your GT-R. This is the perfect brake kit if you drag race, road race or have a high powered street GT-R!
Quicker Acceleration & Improved Braking
Carbon Ceramic Brakes (CCB) evolved from Formula 1 racing and have proven themselves on some of the fastest and most exotic cars including the Lamborghini Gallardo, Koenigsegg CCX and Lexus LFA. Exotic Car Manufacturers chose Carbon Ceramic braking technology because it drastically reduces unsprung weight (rotating mass as opposed to static weight). This is important because if the engine and drivetrain have less mass to get moving, it translates to quicker acceleration and better low end power, not to mention less drivetrain breakage, and quicker suspension response.
The Perfect Brake Package For The Street, Drag Strip AND Road Course
Unlike a drag-only brake option, this kit will improve your stopping power. The Alpha Carbon Brake Package is the perfect mix of lightweight components yet decreases the required stopping distance vs. the stock brakes making it a great option no matter what kind of racing you do.
Only The Best For Your GT-R
The BremboŽ Carbon Ceramic brake rotors utilized in this package weigh almost 50% less than equivalent cast-iron units. They also and have a lifespan of up to 4x longer and are capable of operating at 1,000° C (as hot as molten lava) without warping. These vented vane Carbon Ceramic rotors are 15” in diameter featuring a lightweight, hard anodized aluminum hat and come assembled with genuine BremboŽ hardware. We also include Alpha braided stainless steel brake lines and Endless MX72 brake pads for an all-inclusive package.
Racing Brakes Without The Dreaded Squeaking
Another benefit of the Alpha Carbon Ceramic Brakes is they do not squeak. Normally when you outfit your car with racing brake pads they squeak loudly causing embarrassing situations at stop lights. This typically is an inevitable annoyance with the standard racing pad/rotor combination. With the Alpha Carbon Ceramic brakes however this is a thing of the past. Now you can drive in to that car show, drive thru or nightclub with confidence!
Proven To Stop The World's Quickest & Fastest GT-R
This is the same kit we developed and use on our world record holding, 2000+HP Alpha Omega R35 GT-R which has slowed Omega down from over 185mph drag passes! If the Alpha Carbon Ceramic Brake Package can stop Omega, imagine what it can do for your GT-R!
Exclusive Benefits
  • Quicker acceleration
  • Decreased stress on drivetrain
  • 60lb rotating mass weight reduction
  • Improved stopping power over stock
  • No squeaking found with normal racing brakes
  • Perfect for the street, strip or road course
  • Increased protection against brake fade and rotor warping
Package Includes
  • Four BremboŽ 15" carbon fiber brake rotors and hardware
  • 7075-T6 aluminum hard anodized hats
  • Alpha SS brakes lines
  • Endless MX72 brake pads
  • All necessary hardware
Notes
  • Parking brake shoes and rear dust shields must be removed to install this package
  • Minor clearancing of the rear calipers is necessary for installation. This can be done by using the supplied instructions or the calipers can be sent in for us to perform this service.
http://www.amsperformance.com/cart/a...e-package.html
$12699.95
Reply
Subscribe
