GTR Speed Density conversion kit - Titan Motorsports
SubscribeThe R35 Nissan GTR factory mass air flow sensors have difficulty reading the additional airflow
provided with upgraded turbos and aftermarket blow off valves and in high boost OEM applications. To remedy this problem, the air volume must be converted to a speed density setup requiring the air temp sensor to be moved post-intercooler and a MAP sensor installed. Titan Motorsports has
created a plug-and-play kit that resolves this problem relocating the intake air temperature sensor from the factory MAF Housing to the Upper intercooler upper pipe.
This kit is a recommended upgrade for R35 GTRs making more than 700whp or those wanting to run Vent-to-Atmosphere Blow-Off Valves. This installation takes 5 minutes and the included Plug-N-Play harness allows the car to be returned to stock. It should be noted this modification will require an ECU re-tune calibration for Speed Density, with proper calibration there is no change in drivability.
Included in this kit :
-Intake Air Temperature and Map Sensor (all in one)
– Motorsports Grade Plug and Play Harness
Available Now $359
Available Now $359
