Redline Speed Worx (RSW) Presents: Shop Life
A few more images of the internal engine carnage on this 2.0T TSI due to the failure of the Timing Chain Tensioner. Prior to this level of damage the only sign of the impending doom was a slight chain rattle.
If you have questions on the the Service RSW offers to prevent this from happening to your VW or Audi, Call and speak with our Service Professionals TODAY! 908-223-7477
The newly rebuilt 2.0T TSI engine is back in place in the Audi B8 A4 Avant. The owner is eager to get back behind the wheel after the vehicle's downtime!
The Service Team hasn't even finished the Audi A4 Avant Timing Chain / Engine Repair, and they already have 2.0T TSI Engine #2 Serviced and ready to be installed tomorrow!
The Team is finishing up the Intake Manifold replacement on this Mercedes Benz R-Class this morning!
Did you know we staff a Master Certified Mercedes Benz Technician? Having a difficult time getting your Mercedes properly diagnosed? Contact Our Experts: 908-223-7477
We have a pair of VW Golf R's in the shop this morning. One is receiving a complete clutch system upgrade, the other is in for a bit of diagnostics as well as a maintenance service!
Mercedes Benz C63 AMG stopped in today for a few upgrades to refresh the look of this beastly sedan!
VW Touareg in the shop today for a Transmission Service, Oil Change, Complimentary Inspection, and Serpentine Belt Replacement.
The RSW Service Team is YOUR Dealership Alternative! Contact Us today for all your Service, Repair, and Maintenance needs!
www.REDLINESPEEDWORX.com
New Partnerships in the works for 2015, Stay Tuned!
The RSW Service Team is your Central New Jersey VW, Audi, and BMW Repair / Maintenance Specialist! Whether your vehicle is in need of an engine rebuild, transmission repair, or complete four wheel alignment we can get you taken care of!
Audi B8 A4 2.0T TSI Engine Rebuild / Timing Chain Service #2 for this week just about finished.
Meanwhile in the RSW LAB, we have a VW Golf R 6 Speed Transmission that is being torn down for inspection and repair! The owner was experiencing an issue shifting into 5th / 6th gears, well I think we found the problem.
Remember if you are experiencing hard shifts / engagement or grinding during shifts it is best to have our Service Team perform a Diagnostic Teardown sooner than later, as the damage will only get worse as miles pass . . .
Schedule Appointment
The RSW Assembly Lab is back at it with yet another 2.0T TSI Engine.
Interested in learning WHY we see so many of these engines for internal repair / rebuild?
Read More:
http://redlinespeedworx.com/2-0t-tsi-timing-chain-failure/
Read More:
The RSW Service Team is pleased to present to you the APR, LLC. VW / Audi MQB Gen 3 Downpipe Upgrade! We have put together a complete comprehensive installation article for your viewing pleasure!
If you are looking to take your MQB Powered VW or Audi To the Next Level in Performance Contact Us Today!
908.223.7477 or Visit www.REDLINESPEEDWORX.com
Read More:
http://redlinespeedworx.com/apr-downpipe-upgrade-fwd-1-8t2-0t-gen-3/
Read More:
Do you have a lowered Audi B8 / B8.5? Do you want to get your vehicle properly aligned back towards factory specifications?
The RSW Service Teams keeps a Set of SPC Adjustable Upper Control Arms in-stock for exactly this purpose!
Contact Us Today to Schedule Your Installation, and get your vehicle's handling / tire wear under control!
908 223 7477 or www.REDLINESPEEDWORX.com
This morning we are preforming an ECU Update for this APR K04 customer. Due to the vehicle's ECU Type the RSW Service Team must remove the ECU to update to the newest APR programming which will allow direct port flashing in the future.
It is at this time our Team is reminded why we are the leading APR Technical Center & Master Distributor as all the APR equipped vehicles in the Tri-State Area end up at our facility when it comes to flashing more involved ECU Types or higher levels of system diagnostics. #GOAPR
This B8 Audi S4 3.0T is going to be receiving a full ride height adjustment, new SPC Adjustable Upper Control Arms, as well as a complete 4 wheel alignment today!
If your in need of dialing in your lowered Audi B5, B6, B7, B8, or B8.5 Contact Our Service Team today, we are New Jersey's sports car alignment pro's!
We finally were able to get Pro Circuit Electrical Contracting, LLC over to wire up our Bridgeport! He did an exceptional job of screw driver modeling for this picture.
Busy shop on this Friday Afternoon! Who's ready for the weekend!?
With Spring right around the corner, who is ready to not have a SALTY car anymore? The #RSW Service Team sure can't, as it makes it difficult to keep the shop clean!
When you start to hear noise generating from your vehicle's break system plan to immediately get it checked out. Continued mileage on a system that is / may be compromised is not safe for you or other motorists on the roadway!
Full shop to start this fine Tuesday, not to mention we are upgrading our first VW MK7 GTI to APR, LLC. Stage 2 with the newly released 2.0T MQB Cast Downpipe! #goapr
Sneak peak at our EFR B6 A4 2.0L Stroker build that we have been making progress on!
Now that our Bridgeport is finally up and running we can get the rear uprights from our LOBA Motorsport GmbH B5 RS4 Conversion machined to accept the axles that will mate up with the Skyline Rear Differential!
#becauseracecar
The Mill is certainly up and running. Having the right tooling for the job certainly helps when adapting components to create the perfect end product!
The RSW Service Team loves wrenching on your VW or Audi. With Factory Diagnostic capabilities, and factory trained technicians we are able to service all your Repair, Maintenance, and Upgrade needs here at our facility located in Green Brook, NJ!
Someone isn't wasting any time getting their winter wheel setup off in favor for the new summer wheel & tire package!
If your feeling that "itch" give our Service Team a call! 908.223.7477
Looks like the modified B5 S4 rear up-rights are installed back into the LOBA RS4 Conversion, time to start mocking up the custom mounts for the Skyline Rear Differential!
Our in-house Porsche Specialist on the grind to get this 996 back on the road for the owner to enjoy!
Starting off the morning keeping our Hunter Engineering Revolution Tire Machine & Road Force Touch Balancer busy!
Spring Weather is coming, have you thought about when you are going to be taking your Winter Snow Tires off?
On the other side of the RSW Facility this VW Passat CC is getting a complete four wheel alignment on our Hunter Engineering In-Ground Hawkeye Alignment System!
Audi Direct Injection Fuel System Diagnostics for this B7 A4 2.0T FSI this morning.
Yet another 2.0T TSI VW on the brink of disaster. This 50,000 mile MK6 GTI came into the shop for diagnostics on a check engine light. Upon initial inspection the RSW Service Team found a fault in the ECU for incorrect camshaft correlation.
Our technicians put the engine into time, and after inspecting the engine they found that the timing chain tensioner had allowed the engine to jump time. Luckily we were able to catch this one before any serious damage occurred!
Happy Friday! We are starting the morning off with this 944. The team is diagnosing a few issues for the owner as well as performing a complimentary vehicle inspection.
Got B7's? The RSW Service Team is currently wrenching on (3) B7 A4's and (1) B7 RS4.
This Audi B7 RS4 4.2L V8 is in amazing condition for the mileage. The owner brought it into the shop today to diagnose a "coolant leak" an Audi Dealer was trying to locate for 3 weeks...
If your purchasing used wheels and/or tires don't expect perfect ride quality.
#becauseracecar
Whether your Audi is in need of patching a tire, oil change service, diagnostics or a performance ECU Upgrade our team of experts is here to assist throughout the entire process! Spring is coming, is your vehicle in need of anything?
Schedule an Appointment Online Today:
http://www.redlinespeedworx.com/schedule-an-appointment/
Good Morning, Hope everyone had an enjoyable weekend, the RSW Service Team is well rested and back in action!
APR VW MK6 GTI 2.0T Stage 3+ in for diagnostics this afternoon with the RSW Service Team.
Are you having issues with your APR Equipped VW or Audi? Call our Service Experts today!
908.223.7477 or www.REDLINESPEEDWORX.com #goapr
Lube, Oil, Filter Service for this 3.2 V6 Audi B8 A4. The Service Team also completed a full complimentary vehicle inspection as well!
Our TEAM of Professionals takes the worry out of Service, Maintenance, and Repair for our customers!
Audi B7 RS4 in the shop for a complete vehicle inspection, as well as Lube, Oil, Filter Service!
The RSW Service Team allows our customers to take all the worry out of their vehicle's service requirements over the course of ownership. This over time leads to happy owners & healthy vehicles!
Have New Jersey's potholes been beating up on your vehicle? Call the Service Team today to Schedule to stop by and have your vehicle's four wheel alignment checked, and corrected!
908-223-7477
Another day, another Audi B7 RS4 in the shop for a full Intake Valve Carbon Cleaning Service. This particular RS4 has rather high mileage, and has never had the serviced completed. So we're quite interested in how the build up is!
We love the timeless styling of the E46 BMW Chassis. . . especially when it's sitting on our Hunter Engineering In Ground Hawkeye alignment rack!
It has become quite the common occurrence for us to see failure of the Audi / VW 2.0T TSI Intake Manifold. We are practically replacing them on a weekly basis!
If you had your pick, which would you consider the ultimate driving machine?
Audi vs. BMW : RS4 vs. M3
908-223-7477
The only true gauge for the quality of our services is when we get feedback from our customers . . .
"You guys were great today. Was having a problem with my fog lights and I paid for an hour of diagnostic. Every time the tech found something he came outside to let me know and asked If wanted to keep going with the repairs. It was Nice getting updated with what was going on with the wiring. Highly recommend the guys here from the professionalism of the front desk all the way to the knowledge of the techs plus the comfy seats and big screen tv isn't too either. Thanks again."
Thank you for the kind words Mike!
With over 100,000 miles on this Audi RS4 and never receiving an Intake Valve Carbon Cleaning Service, the build up was extensive. Some of the upper portions of the ports were almost completely blocked!
The RSW Service Team is positive the owner is going to see a noticeable difference in his RS4 on it's ride back home!
The carbon buildup in the Audi B7 RS4 from yesterday was pretty significant, the Service Team is still working its way through each port with our factory walnut shell blasting equipment. One of our technicians pulled this pile of gunk out from behind one of the valves....
If you own a 4.2L V8 RS4 you should either have had this service completed, or being calling us today to schedule your appointment!
908-223-7477 or www.REDLINESPEEDWORX.COM
The results after cleaning the intake valve & chambers with our Factory crushed walnut shell equipment is quite impressive!
Service & Maintenance is what our Team does best. Do you need to develop a maintenance / repair plan for your vehicle?
Contact our experts today to discuss what is required vs. what is going to be needed over the course of ownership of your vehicle.
Let us put our extensive knowledge to work for you!
The RSW Service Team is happy to now be a contributing sponsor to the NNJR PCA! Whether it's a daily driver, weekend cruiser, performance monster, or track beast our team has the knowledge & expertise to take all the worry out of Porsche Ownership!
Something a little out of the "Norm" for the Service Team. Saab SUV in for a rear differential service / rebuild!
With what will hopefully be the last blast of winter weather coming tomorrow it's not quite yet convertible weather, BUT best to be prepared for when those warmer temperatures do reach us here in New Jersey!
The Service Team is working to resolve issues with the operation of this Audi TT's drop top this morning!
The RSW Service Team is proud to have this new Sepang Audi S3 2.0T in the shop for its' first round of upgrades! Today it will be receiving a set of H&R Springs as well as an upgraded rear sway bar!
Putting our BMW Factory Walnut Blasting equipment to work on this N54 powered 335.
Do you need this service completed on your BMW? Call and speak with one of our experts today!
908-223-7477
908-223-7477
VW Golf R Owners & Audi S3 Owners: How does +74HP & +98TQ Sound?
APR's ECU Upgrade is here! The MK7 Golf R and S3 ECU Upgrades are released for the North American market!
Contact the RSW Service Team Today to Schedule Your Appointment!
http://redlinespeedworx.com/apr-high-output-2-0-tsi-gen-3-ecu-upgrade-audi-s3-vw-golf-r/
The RSW Service Team provides a true Dealer Alternative for our customers. When it comes to OEM level repairs, service, or maintenance our Team will ALWAYS come out on top when compared to your local dealership.
We offer the same parts, the same diagnostic tools, and same level of technicians skill all at a more competitive price point!
Rise & Grind! Looks like Spring has officially arrived by the looks of all the tire work we have to complete with our Hunter Engineering Company Corporate Equipment!
Another busy week in the books! If your vehicle is ready to come out of winter hibernation mode contact our Service Team today!
Another BMW 3 Series in for a full intake valve carbon cleaning service this morning. Gain back both fuel economy & lost performance due to SLUDGE build up!
Have you had this service completed on your N54 yet? If no, Contact our Service Team Today!
Audi B5 S4 Avant in the shop this morning for a complete 2.7T Timing Belt Service. The RSW Service Team is also taking this time in the shop to address a few oil leaks, nothing new valve cover gaskets & camshaft seals won't fix!
Spring is here, Contact Us Today to Schedule your vehicle's service, repair, and maintenance needs before the driving season begins!
The NEW FlowForm HRE Performance Wheels FF15 20" Display Wheel has arrived to the RSW Service Team. If you are in the area be sure to stop by and check it out!
A few "in-progress" shots of the 2015 Audi S3 the RSW Service Team completed the first round of upgrades on yesterday. It received a set of H&R Lowering Springs as well as an H&R Rear Sway Bar!
If your thinking about upgrading your MQB Haldex Powered S3 give our experts a call today to discuss your options!
908-223-7477
After completing the installation of all the components we got the S3 on our in-ground Hunter Hawk Eye Alignment System to do a preliminary alignment to ensure the vehicle would be good to go for the owners' up-coming road trip.
Here is finished shot of the Sepang S3
The RSW Service Team works hand in hand with our customers to ensure proper "fleet" maintenance. Many of our customers own multiple vehicles, and we do all that we can to provide the same excellent service across any / all family fleets!
After repairs were complete on this customer's Mercedes, it was picked up, and this Range Rover was left in its place to have a new set of tires mounted, balanced, and then aligned!
Have a family fleet? Contact Us today to learn what our Service Team can do for you!
Someone is getting a new Milltek Exhaust System
. . . and the vehicle that received the new Milltek Sport USA Exhaust System was this new 2015 Audi S3! The owner decided on the fully valved non-resonated system with quad black tips! The Service Team thinks it was the perfect edition! Next up, and APR, LLC. Stage 1 ECU Upgrade! #GOAPR
Don't neglect your vehicle, work with our Service Team to build a Maintenance Schedule that best works for you! Once implemented, one of the things we will ensure is that your spark plugs never come out of your engine looking like this . . .
Call and speak with an expert today: 908-223-7477
The Team upgraded this VW CC 3.6 4motion this morning with a set of KW suspensions Coilovers! Next up on the list a new set of wheels / tires, and a ECU Upgrade!
The RSW Service Team has another happy VW MK7 GTI owner out on the road enjoying an APR, LLC. Stage 1 ECU Upgrade, as well as an APR Carbon Fiber Intake System! #GOAPR
Do you own a 2015 GTI, A3, Golf R, or S3 and want to unleash the beast? Call our Experts today to Schedule your appointment!
908-223-7477
Time for a fluid change on this Porsche Cayenne! Not only will it be receiving a complete Lube, Oil, Filter Service, but a Brake System Fluid Flush as well!
Spring is here, keep your vehicle's operation in peak condition for the up-coming summer!
Back on the grind this rainy Thursday Morning. Starting off our daily dose with diagnostics on this Mercedes S 500.
Did you know the RSW Service Team is equipped with a Master Certified Mercedes Specialist? If you are experiencing any type of issue with your new, used, older Mercedes Contact Us Today.
The time has come to get those winter wheel setups off your vehicle! While your vehicle is in the shop let our Service Team complete a complimentary alignment inspection to ensure your vehicle will be properly tracking & handling on that new set of wheels and tires!
We have some-what of a unicorn in the shop today, a beastly A V10 TDI Touareg!
New Jersey's road have put a beating on this truck over the winter months, time for the RSW Service Team to get it's alignment back in check!
Another Happy HRE FlowForm FF01 Customer! The RSW Service Team is very happy with the outcome on this project!
908-223-7477
908-223-7477
S65 V8 equipped BMW M3 has just been dropped off to the RSW Service Team for a complete complimentary vehicle inspection, as well as rod bearing replacement.
If you own a higher mileage E9x M3 S65 V8 and have questions about this service, contact our experts today, 908+223-7477.
Diagnostic time for this BMW 3 Series N54.
The RSW Service Team found several of the N54's fuel injectors to be the root causes of the customers concerns!
BMW X5 in the shop this afternoon for wheel and tire replacement and complete four wheel alignment. It's turning into a BMW day here at Redline Speed Worx.
RSW Service Team employs the use of the leading diagnostic equipment ensure ensure repairs are completed in a correct and timely fashion to limit our customers vehicle's downtime.
We have full Factory Level System for the entire BMW product line!
Keeping with our BMW themed Friday here at Redline Speed Worx, LLP, the Service Team appears to have the S65 E92 M3 prepped & ready for surgery....
Good morning! It's Monday, the RSW Service Team has another BUSY week ahead! Starting the morning off with a touch of maintenance on this D3 Audi A8!
Progress on the BMW S65 M3 V8 Rod Bearing replacement service continues this morning.
Do you have a higher mileage E9x M3? Contact our experts today to discuss when you should be addressing this engine service!
BMW E46 M3 in the shop this AM to upgrade over to a new set of wheels & tires. Looks like someone is ready for the warmer weather!
One lucky RS4 is receiving a new OEM Audi wheel!
The RSW Service Team has been busy today! It's always nice to have such a spread of different vehicles in the shop, especially on a Monday!
VW MK7 in for a complete four wheel alignment, BMW X3 is getting a bit of diagnostics this afternoon, and the 991 GT3 is receiving it's new exhaust!
Progress continues on the S65 V8 M3 Connecting Rod Bearing Replacement Service . . .
New Jersey's BMW Specialist. Today the RSW Service Team is taking care of a summer tire service on this X5M.
Our Hunter Engineering Company Corporate Roadforce Touch Balancing System makes for a VERY precise wheel & tire balance!
It's time for this Porsche 991 GT3 to receive its upgrade exhaust from our friends at GMG Racing!
VW Tiguan in for a 40,000 Mile Scheduled Maintenance today.
If you need a quote on an up-coming mileage related service, or have questions about what may be included do not hesitate to contact one of our experts today! (908) 223-7477
The BMW E92 S65 V8 M3 Engine is receiving a set of APR Custom Aged 625+ Rod Bolts during the course of its engine service.
What is the difference between ARP 625 and ARP 2000 bolts you ask?
The tried, true, and very popular ARP 2000 material is a quench and tempered heavily alloyed martensitic steel with a typical 44-47 C- scale Rockwell hardness and rated at 220,000 psi tensile strength. The ARP Custom age 625 + counterparts are comprised of a higher tensile strength super-alloy corrosion resistant material, also quench and temper heat treated, to a robust 260,000psi.
It's Wednesday, and the BMW S65 Engine Service is complete, thought we would share a few pictures of the bearings we pulled out of the E92 M3, keep in mind this BMW only had 36,000 miles on it.
If you own an E9x BMW M3 and are interested in this service please contact our experts today with questions, pricing inquiries, or to schedule your appointment!
Contact Us Now.
Contact Us Now.
