Other Italian Supercars Alfa 8C, Pagani Zonda, Cizetta etc.
GMP Performance presents Neu-F: Products for the Fiat 500s from Neuspeed
Old Jun 12, 2013 | 12:17 PM
GMP Performance's Avatar
Site Sponsor
NEUSPEED has been providing well designed, engineered, and high quality manufactured parts to the automotive industries for close to four decades. They have won American Touring Car Championship Series with their Honda Accord race car, built project cars for Volkswagen AG, and in 2008 they became a premier performance parts manufacturer for the Gen 2 MINI Cooper market. They are committed to quality, refusing to sacrifice just to reduce costs for themselves. All their parts come from a special pride that is hard to come by nowadays, a pride that in turn promises craftsmanship, attention to detail, and dedication to their products.
All those amazing qualities are now being aimed in an additional direction; They are proudly introducing 'Neu-F', the all new tuning brand for Fiat vehicles. Concentrating on the Fiat's unique characteristics, their goal is manufacturing great parts to help maximize all you can get out of your 500!
Neu-F performance lowering springs reduce body roll during cornering, and front end dive under heavy braking. Plus, the kit also reduces wheel-well gap to create a more aggressive look for your car.
Why our springs are different from our competitors'?
Based on our experience and the results of intensive R&D, we concluded that the factory Abarth has near perfect 'spring rate to vehicle weight ratio'. The car handles well out of the box so we decided to increase the spring rate slightly and only reconfigure the static height. This lowers the center gravity and gives an even front and rear stance. This also enables the car to keep ride quality similar to stock Abarth's firmness and rely on sway bar upgrades to enhance the handling characteristics.
The Fiat 500 turbo/Abarth's rear suspension does not have a common 'sway bar' because, technically, no part of it is connected to the subframe. We call this a torsion bar because it works by countering any twisting motion on Fiat's rear axle beam (and not independent) suspension.
Neu-F 28mm rear torsion bar is the perfect upgrade from the 22mm stock diameter bar. Its diameter has enough size jump to actually make a difference and keep the back-end flat. This will essentially help to induce more over steer. If you drive your Turbo Fiat as it meant to be driven, then you need this bar to take the handling to the next level. Featuring powder coated aerospace grade steel material with remarkable shape memory, and knurled ends for solid mounting.
The Neu-F Bars will improve cornering potential due to increased front/rear roll stiffness that offers definite track and autocross advantage over stock anti-roll bars. Increased slip angle will allow power to be applied earlier during corner exit.
Neu-F Front Anti-Roll Bar is made with aerospace grade steel material with remarkable shape memory and is formed utilizing CNC Mandrel bender which ensures smooth bends, accurate shape and consistency through out its length. The bar also features forged ends with 2 hole for a 3-way adjustability that allows suspension to be finely tuned for optimum handling balance.
Also Included are billet aluminum 7075-T6 CNC machined bushing clamps with a black hard anodized finish for durability. The billet clamps are equipped with grease fittings which allow users to re-grease the bushings with ease. The low resistance, graphite impregnated urethane bushings round out the package.
The Neu-F Bars will improve cornering potential due to increased front/rear roll stiffness that offers definite track advantage over stock anti-roll bars. Increased slip angle will allow power to be applied earlier during corner exit.
Neu-F's Patent Pending short shift adapter is made utilizing CNC machined Chromoly Steel. This material is known for its high Rockwell hardness which gives the adapter its strength and rigidity. Another good characteristic of Chromoly is its material density and weight. The heavy and solid adapter acts like counter weight, giving the forward/aft shifting motion a much smoother feel, eliminating notchy gear engagement.
Since our kit is a mere adapter and not a complete lever, it is naturally cost a lot less to machine compared to the full lever kit currently available in the market. Also, by not having to replace the entire assembly like our other competitor's products, the installation procedure will be much simpler. With less parts to remove, this reduces the chances of damaging stock components. Neu-F Short Shift Adapter reduces 25% of shift travel, which is about maximum before the ball linkage starts contacting and damaging the center console.
The Neu-F RSe05 is a wheel with unmatched quality, perfectly spec-ed for your Fiat. With its design adapted from the European touring challenge cars and weighing just a mere 16.5 Lbs., the RSe05 will enhance your driving experience cosmetically as well as performance by reducing the rotational mass or unsprung weight. The instant benefits would be: lighter steering, shorter braking, and responsive throttle feel.
- HUB CENTERIC. We machined our wheels to fit factory brake hub WITHOUT the use of any 'hub center rings'.
- Center cap opening is machined to accept OEM ABARTH CAP for the clean factory look.
- OEM TPMS (Tire Pressure Monitoring System Sensor) compatible.
- OEM LUG BOLTS compatible.
- Will clear all BIG BRAKE KITS available in the market.
- ROTARY FORMED aluminum alloy.
Offset: +35 mm
PCD: 4-98mm
Bore: 58.1mm
Lug Seat: Conical
Weight: 16.5 lbs. (7.5 kg)
OEM Fiat Abarth Center Cap
For more information on this awesome new product line, click any of the links above the pictures or click here to see the entire line up!
Old Nov 18, 2013 | 01:10 PM
Site Sponsor
Now available from Neu-F: a stainless steel catback exhaust and catback mid pipe!
For more information on this or any of the parts above, be sure to message us or comment below!
ID:	302796   Click image for larger version
Old Dec 26, 2013 | 02:56 PM
Site Sponsor
Bump for some great upgrades for Fiat 500s! Be sure to message us with any questions.
Chris Green@USP
997 Turbo Vendor Classifieds
Jan 28, 2016 02:22 PM
Sep 14, 2015 06:42 PM
ECS Tuning - VW
Aug 21, 2015 09:11 AM
ModBargains
Aug 20, 2015 12:28 PM
Chris Green@USP
996 Turbo Vendor Classifieds
Aug 20, 2015 11:30 AM
