Final Photoshoot of Veilside Fortune Widebody with New Stereo Installed NO 56K
Bad ***. The car looks great. BTW - Thanks for using our audio gear, much appreciated. Have you forwarded any of the pics and details to Rockford marketing???? PM me if you need the contact information.
Mod List
Exterior
snipped...
Engine
- street port engine (Redline Engineering) 11k miles
- new 2 mm seals
- new rotor housings
- cryogenically treated engine seals
- lightened, clipped, and balanced rotors (Racing Beat)
- intake ports polished
- new pinned housings and other special machining for sand-rail motor (Redline Engineering)
Turbo
- HKS T04E single kit
- Greddy Front Mount Intercooler
- HKS SSBOV
- APEXi AVC-R Boost controller
- HKS air filter
Cooling
- Koyo Aluminum radiator
- Earl's 32 row oil cooler
- Unorthodox pulley set
Transmission/Drivetrain
- KAAZ 2-way LSD
- MazdaSpeed Power-Plant-Frame RARE
- B&M Short Shifter
- ACT street/strip clutch w/ extreme pressure plate
- Racing Beat 11 lb alum. flywheel
Fuel Management
- PowerFC computer tuned by XS Engineering w/ commander
- 660 cc pri, 1200 cc sec RC injectors (flowed and blueprinted)
- SX fuel pressure regulator
- Denso fuel pump
- Magnecor plug wires
- HKS iridium spark plugs
- B&M Newvolt Ignition Amp
- HKS Grounding System
Exhaust
- ceramic coated exhaust manifold,
- ceramic coated exhaust housing of turbo
- ceramic coated down-pipe
- HKS Carbon Fiber Titanium Exhaust
Suspension/Brakes/Wheels
- Rotora 6 Piston 14" Front Kit
- Rotora 4 Piston 13” Rear Kit
- New Mazda 929 brake master cylinder
- CWC sway-bar mounts
- Racing Beat front and rear sway bars
- Cusco front strut bar
- Tein Flex Coilovers
- Tein EDFC
In Car Electronics
- Pioneer Avic D1 Navigation Head Unit
- Custom Fiberglass Amp Rack
- Custom Fiberglass Sub Enclosure
- 2 Rockford Fosgate T152S POWER series 100 Watt RMS, 5.25” component system
- 2 Rockford Fosgate 2001bd POWER series AMP
- 1 Rockford Fosgate T18004 POWER series AMP
- 4 Rockford Fosgate T110D2 POWER series 10” woofer
- Lightning Audio AMP and Power Wires
- Optima Yellow Top Battery
- 2.5” Rear View Monitor
Exterior
snipped...
Engine
- new 2 mm seals
Turbo
- HKS SSBOV
- HKS air filter
Cooling
- KAAZ 2-way LSD
- B&M Short Shifter
Fuel Management
- Denso fuel pump
Exhaust
- Tein EDFC
In Car Electronics
My wife totally misses the car. The car was very fast! 403 rwhp at 1 bar.
Let me know or send me an email if it was. I don't get on here and just registered.
regards
Rick
2001 911 Turbo - For Sale
17k miles, complete RUF exhaust, rare hardtop! $55k OBO
2007 E63 - P30
2004 Nissan Titan
2006 G.P. Kart
125cc full-DDR Honda Shifter
I have found your car,an i see sell this ????
http://suchen.mobile.de/fahrzeuge/sh...de&tabNumber=1
Or FAEK ????
Or FAEK ????
That car makes no sense!!! You killed the rx-7 and wasted a ton of money in the process.
And by the way... Lambo doors are so played out lambos don't even use them.
I don't mean to hate on your car but when I see something thats not useful it bothers me. Racing or Show!! It makes no sense with the fact that it has carbon fiber and other weight reduction done but then you got 200 pounds of speakers and amps then a Tv and a removable steering wheel and a roll cage???
I do like the rear end of it though.
