RH9 - 2011 Subaru STI Build
First of all RH9 designation means:
9 second 1/4 mile on street tires/drag radials
1.0g's on street tires
under 110 ft 60-0 breaking on street tires
Side note - I will compete in the Shift Sector roll racing events in California as well, because the drag racing will wreak havoc on the drivetrain parts and I am sure I will get tired of replacing stuff if it breaks.
I am building the car to meet the above criteria!!!!!
Current - So I popped the stock motor last year and now onto the rebuild. This journey has taken me some time but I am very happy where it is ending up.
I am going to skip to the end and say what is in build in my search to become the first 9 second, full weight, daily driver, GR Subaru STI in the 9's on street tires/drag radials.
First of all my STI has about 300 pounds of additional weight beyond stock from complete sound deadening and stereo system
, plus I weigh 250+!!!!
Now on to the good stuff.....
Block - Completely Balanced and Blue printed.....
Darton Sleeved
Pinned Mains
Oil mods
Carillo Rods with ARP Aged +625 bolts
Nitrided Crank
ACL Race Bearings
New 11 STI Oil Pump
Ross FSR pistons
ARP +625 Aged head studs
TigWerks Oil Pickup
Heads
11 STI heads fully ported and polished
O-rings
Forgot the springs/retainers/seats, will update when I ask Joe
SuperTech +1mm Inconel exhuast valves
SuperTech +1mm Nitrate intake valves
GSC 272 cams
Head Gaskets, will update
TGV Deletes
8mm Phenolic Spacers
NA Intake Manifold Pnp'd and port matched through the phenolic spacers and TGV deletes
ID 2000 Injectors
Fuel System to be sorted out with a dual pumper in tank setup
Borg Warner S472 turbo T4 1.10 a/r in twin scroll set up, but not using twin scroll headerQuick Spool Valve
75mm Throttle body
ACT 6 puck clutch and flywheel
Heade/Up Pipe - I am still up in the air about where we are going to mount the turbo and which company to use. Mike with 5250 Performance will help me with this decision....
Gates Racing Belt
ATI Fluiddamper
More pictures are coming as the build nears completion.....
Love to read about your opinions....
Link to thread on nasioc with pictures...... http://forums.nasioc.com/forums/showthread.php?t=2498526
Darton Sleeved
Pinned Mains
Oil mods
Nitrided Crank
ACL Race Bearings
New 11 STI Oil Pump
Ross FSR pistons
TigWerks Oil Pickup
Heads
O-rings
GSC 272 cams
TGV Deletes
ID 2000 Injectors
75mm Throttle body
Gates Racing Belt
ATI Fluiddamper
Last edited by GT3 Chuck; May 3, 2013 at 03:06 PM. Reason: active links and link to another forum
start collecting spare transmissions as you are going to need them
sounds like a fun project.... but some serious weight reduction will help to prevent parts breakage, and make your goals much easier.
If you want to be middle of the road at the airport shootout events and hang with 600rwhp supercharged M3's that trap 160mph+ then your project will be fine. To run with the big dogs you are choosing the wrong platform and need another 300rwhp and better aerodynamics.
I agree the car is going to be very heavy, about 3850-4000lbs wet.
I am trying to set a goal and be the first with a Subaru STI.
I know it isn't considered the best platform by some, but it is what I have currently.
Thanks for your advice. I hope to see you at the event in November.
One,
The wheels you all have are just fantastic looking. I wish your website had the photoshop ability to showcase your wheels in a profile view on different cars, especially my STI. LOVE your product!
joeyharp
Aug 29, 2016 09:41 PM
