Help needed ! Check coolant level warning
Old Jan 18, 2011 | 05:40 PM
ateles's Avatar
ateles is infamous around these parts
All,
I have been getting a warning to check the coolant level every time I turn the car on ...This has been happening since the winter started in earnest and I am suspicious that this warning has to do with the low temperatures ( I am in NYC).
Basically , when I start the car I get the visual warning and I noticed that the coolant temp level goes immeditially to the max temp even though the car is cold and to solve it I have to keep trying to start the car for several times .
Have anyone experienced this issue ? Any clue / suggestions?
Old Jan 19, 2011 | 09:56 AM
MrMan's Avatar
MrMan is infamous around these partsMrMan is infamous around these parts
This happened to me recently, exactly same circumstances. I shut off the car immediately upon seeing that the temperature had spiked when I started the car. I had them tow it to the dealer, where it was for 10 days.
Old Jan 19, 2011 | 10:18 AM
ateles's Avatar
Thanks for the reply ... I tried a few times and it worked fine and I drove afterwards at normal temperatures ... So the coolant level is not the problem really ... It is some sort of electronic glitch .. What was the dealer diagnosis/solution?
Cheers ,
Aloisio
Old Jan 19, 2011 | 01:06 PM
medici78's Avatar
medici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud of
If you know its cold and it immediately indicates it's hot, obviously its an electronic glitch. Good luck!
Old Jan 20, 2011 | 01:32 PM
Snail's Avatar
Snail is infamous around these parts
Temperature light on
I believe there is a Technical Service Bulletin, TS-1008-9752, about this issue. Search the NHTSA site for the TSB (Technical Service Bulletin). http://www-odi.nhtsa.dot.gov/cars/pr...sb/results.cfm
Old Jan 21, 2011 | 05:15 PM
P4S2010's Avatar
P4S2010 is infamous around these parts
Originally Posted by ateles
All,
I got this last week. I was at a ski resort and had left the car outside on a very cold night. The warning went away after a few minutes of driving.
Bulletin Number: TS-1008-9752
PORSCHE: CHECK ENGINE LIGHT ILLUMINATED WITH VARIOUS FAULT CODES STORED IN THE DME. THERE IS A POSSIBILITY OF FAULTY SPLICE POINTS IN THE ENGINE WIRING HARNESS WHICH MAY CAUSE VARIOUS FAULT CODES. *PE
COBB Tuning
Jan 1, 2025 09:02 AM
00aston
Aug 24, 2015 09:29 AM
Fadi
Aug 21, 2015 03:43 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
