Removing entry and drive plastic key
Old Sep 30, 2011 | 07:03 AM
Mojosan's Avatar
Mojosan is infamous around these parts
I've had issues at car washes with all the keyless entry systems. I insert the regular key all the time.
Porsche's setup is really the worst on this. Not sure what they were trying to accomplish or improve upon with the "blank" key.
Old Sep 30, 2011 | 07:44 AM
Zlaatan's Avatar
Zlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant future
I don't want to be the negative guy here but.. Aren't you guys worried about the theft aspect of all this. If someone walks past a car which looks to have the key left in the ignition, wouldn't they be more inclined to smash a window and try to steal the car?
A starter button is much better option imo. Better looking, more fun (well I think so at least..) and "safer".
Does Porsche have the key just to keep the traditionalists happy so the can still have the ignition to the left of the steering wheel?
Old Sep 30, 2011 | 01:12 PM
jisuro's Avatar
jisuro is infamous around these parts
I think you are right. Fake key may entice someone to break a window to try out the key! Probably a matter of time before Porsche goes to a button.
Old Sep 30, 2011 | 02:01 PM
jmmk's Avatar
jmmk is a name known to alljmmk is a name known to alljmmk is a name known to alljmmk is a name known to alljmmk is a name known to alljmmk is a name known to all
I just went and looked through all the windows of my car and the "fake" key, as you call it, is not visible from the passenger side through either window. It is not visible from the rear window and is only slightly visible through the driver's window. From there, in bright light, it looks more like the headlight switch above it than it does a key since it is black like the dash and other switches. A thief would have to know a little about Porsche's somewhat unusual key location to even think to look there for a key and if they knew that much about the Porsche they would know that key wouldn't work without the accompanying "smart" key.
And if you are so worried about a thief trying it out, why not just remove the "fake" key, just like you would a real key and solve the problem just like you would have before this was invented.
I haven't heard of any instances you are describing, though far-fetchedly it is possible, though not probable. If you are worried, just remove it and quit worrying.
Old Sep 30, 2011 | 02:04 PM
kip's Avatar
kip
kip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to behold
You have a point there.
Living with the plastic key and now knowing I can remove it easily has made life acceptable, but I was expecting a start button too.
Old Sep 30, 2011 | 02:29 PM
jisuro's Avatar
I still love keyless go and would never buy a car without it!
Old Jan 3, 2013 | 09:11 AM
Snowczar's Avatar
Snowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to behold
I have a 991S Cab coming with the Porsche Entry and Drive. Question re car washes. The one I use is a hand wash and I stay in the vehicle when they do the wash. Am I far enough away, in the driver's seat so that when they wash the lower part of the front hood that the hood won't pop open? When they do vacuming I turn off ignition and get out of the car.
John in Vancouver
Old Jan 3, 2013 | 11:29 AM
Bamamarcus's Avatar
Bamamarcus is infamous around these parts
Ok, i'll ask the stupid question. Why does it have to be removed for towing?
marc
Originally Posted by jisuro
Makes sense jmmk, thanks.
Old Sep 21, 2015 | 05:45 PM
EmmHolla's Avatar
EmmHolla is infamous around these parts
So I purchased the metal key fob.. Only to find that my '12 P4S doesn't have the same turn to the left procedure as prior models.. Anyone know how to remove the plastic porsche entry and drive key fob on '12 and newer Panamera's?
Old Sep 21, 2015 | 06:37 PM
EmmHolla's Avatar
For anyone looking to figure out how to remove the plastic key fob on 12 and newer models see link below. I suppose this page is in the drivers manual as well..
http://www.porscheownersmanuals.com/...anamera/5/145/
Old Sep 21, 2015 | 07:14 PM
NiceCar's Avatar
NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !
Funny, I didn't use that method to get the key out of my '13 model once. I think I pressed it in and turned it, or something like that, and it just came out.
Old Sep 21, 2015 | 08:50 PM
cheetos72's Avatar
cheetos72 is infamous around these parts
What seemed to work for me is without he keys In the car turn to start once, get the complaint that no key found, turn off and then to start again, one more complaint. Finally turn back to off again and you'll hear a click of the key blank being released. Pull out the blank (should come out easily)
Old Sep 23, 2015 | 03:10 PM
EmmHolla's Avatar
This worked for me. Thanks
Old Sep 24, 2015 | 02:46 PM
iammulva's Avatar
iammulva has a spectacular aura aboutiammulva has a spectacular aura aboutiammulva has a spectacular aura about
I say this knowing full well you will have a good laugh at my expense.
Not only did I not know how to remove the entry and drive plastic "key", I didn't even realize that it could be removed. What's worse, until today, I didn't know that the actual key worked as an actual key. Today was the first time since I bought my car (in June) that I put the key in the ignition.
Old Sep 24, 2015 | 02:52 PM
NiceCar's Avatar
And I bet you found weren't missing the fun of putting a key in the ignition either. I hate having to deal with the key.
