Panamera Turbo 700hp + Project
2 Attachment(s)
Here is a dyno graph of my Panamera turbo on a Mustang Dyno with Sport Plus mode activated.
The car ECU is stock and waiting for remap this days. The mods i have is: Upgraded Turbochargers, Sport Exhaust with straight pipes, Billet diverter valves, BMC air filter, custom made high flow y-pipe and Pulstar pulse plugs. |
Look forward to reading more about this. Post some pictures of this beast when you get a chance.
Ok i will... :)
2 Attachment(s)
It seems my PDK is broken or it is not designed to hold that much torque... :(
Interesting, so if I am reading this correct you have over 800FT/LBS of torque at the wheels but only just over 500whp at the wheels? Any idea why you there is such a disparity? I just find it odd that there is that much of a difference, usually on these cars HP and TRQ are pretty close.
Sad to hear about the PDK, was hoping it might be a bit more durable than this. Do you happen to have a dyno run sheet that has a line that shows the boost pressure held at each RPM? That would be very helpful. I plan on implementing similar upgrades sometime later this year so I am very interested in whatever information you have to share. Thanks, Jeff |
Originally Posted by jaatlee
(Post 4027147)
Interesting, so if I am reading this correct you have over 800FT/LBS of torque at the wheels but only just over 500whp at the wheels? Any idea why you there is such a disparity? I just find it odd that there is that much of a difference, usually on these cars HP and TRQ are pretty close. Sad to hear about the PDK, was hoping it might be a bit more durable than this. Do you happen to have a dyno run sheet that has a line that shows the boost pressure held at each RPM? That would be very helpful. I plan on implementing similar upgrades sometime later this year so I am very interested in whatever information you have to share. Thanks, Jeff
I have heard that the PDK in the Panamera is having a hard time holding that much torque. This is around the same hp/tq levels I am at in my CTTS (approx 600 awhp; same engine) with no issues for over a year and a clean dyno chart. However, we have an automatic Aisin TR60SN transmission.
Without knowing for sure, this does look like clutches slipping.. I would suggest dropping into the 991 911 section and see if any tuners have any experience strengthening the PDK clutches. |
Originally Posted by Renaissance.Man
(Post 4027420)
I have heard that the PDK in the Panamera is having a hard time holding that much torque. This is around the same hp/tq levels I am at in my CTTS (approx 600 awhp; same engine) with no issues for over a year and a clean dyno chart. However, we have an automatic Aisin TR60SN transmission. Without knowing for sure, this does look like clutches slipping.. I would suggest dropping into the 991 911 section and see if any tuners have any experience strengthening the PDK clutches.
Originally Posted by iglambo
(Post 4027431)
600 AWHP, at what dyno did you get that numbers?
Here is the dyno: https://www.6speedonline.com/forums/...ine=1389988897 |
(Post 4027432)
I said approx 600awhp. This dyno chart is a little outdated at 582 ft lbs tq. Since then I have added methanol injection, full 3" exhaust, and currently working on a bigger y-pipe intake. These three should have me closer to the 600 awhp number once I can get it redynoed. Here is the dyno:
we have done same project here before.
turbo S upgraded turbos bmc filter downpipe full exhaust car 70-250kmh was ahead by 8 cars from stock panamerat turbo |
Originally Posted by cayenne_ksa
(Post 4027445)
we have done same project here before. turbo S upgraded turbos bmc filter downpipe full exhaust car 70-250kmh was ahead by 8 cars from stock panamerat turbo Video Link: http://www.youtube.com/watch?v=BI6XuTO3fXU
(Post 4027447)
Did you have transmission slipping like me?
(Post 4027448)
the car has been running for almost 2 yrs now with no issues
(Post 4027450)
What torque you had to the wheels?
