TPMS malfunction?..
Old Jul 16, 2014 | 06:42 PM
GladiatorOwner's Avatar
GladiatorOwner is infamous around these parts
TPMS malfunction?..
Ok, my right front sensor keeps acting up. The tire/wheel is fine and holding pressure so it's the sensor or ? The reading in the car after a few trips around town reads -4 psi. I've reset it and it then works and reads correctly (checked with a few pressure gauges) ... Also didn't whack anything like a pothole, etc. so nothing was jarred or loosened. Just started reading incorrectly.
Specs are 2012 PTT.
Does anyone know if it's the sensor or the system itself?
Old Jul 16, 2014 | 07:29 PM
MIA997TTBeast's Avatar
MIA997TTBeast is infamous around these partsMIA997TTBeast is infamous around these parts
Lightbulb
Specs are 2012 PTT.
Do you have bigger tires than stock? This happens to me after 2-3 hours long trips.
My tires "lose" air after hot/cold environments.
I just put air.
If stock, and if not losing air, then TPMS might be going.
Old Jul 16, 2014 | 07:49 PM
I have OEM 20" turbo IIs. It occurs intermittently and only when I shut car down.
I'm guessing sensor is going. Only 20k miles but never had an issue with any sensors so not sure of lifespan.
Old Jul 16, 2014 | 08:04 PM
PanaZilla's Avatar
PanaZilla is infamous around these parts
Sensor hopefully.
Old Jul 18, 2014 | 10:26 AM
Fkim011's Avatar
Fkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant future
Doesn't the sensor have a battery in it that needs to be replaced? I remember reading something like that a while back....
Old Jul 22, 2014 | 10:55 PM
orange997TT's Avatar
orange997TT is just really niceorange997TT is just really niceorange997TT is just really niceorange997TT is just really nice
Negative the sensor batteries are not replaceable. U can buy a set if 4 on eBay or thru the forums for less than 200 delivered.
need4speedmotors
996 Turbo Vendor Classifieds
Jan 12, 2016 05:41 PM
C5tt
Oct 24, 2015 07:35 PM
freddiemac
Oct 7, 2015 11:05 AM
miken168
Oct 6, 2015 09:21 AM
need4speedmotors
997 Turbo Vendor Classifieds
Sep 28, 2015 04:47 PM
