4s front brake pad replacement
Old Apr 21, 2015 | 04:09 PM
maverick997's Avatar
maverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to all
Well apparently not a lot have done this yet. Can't find any DIY here or on the web. Anyone have any tips pointers for changing front pads? I have done many brake jobs but not on the Pano.
Thanks in advance
Old Apr 22, 2015 | 09:38 PM
Logimind ......many thanks.
Old Apr 27, 2015 | 12:00 PM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
its pretty straight forward if you've done brakes on other cars. the monoblock calipers Porsche uses on all the newer/current cars is not as convenient as the older brembo caliper design, where you just remove the 2 pins and slide the pads out from the top. you have to remove the caliper, its secured by 2 triple square bolts. and the pads slide out from the bottom. I re-torque the caliper bolts to 75 ft/lb. its easy if you know what you're doing. theres a diy write up on the 991 forum, its essentially the same procedure.
Old Apr 28, 2015 | 05:47 PM
MikeL, thanks for the info ill check out the991 forum. When I do it ill try and do a DIY.
2lflat4
Nov 18, 2019 05:05 PM
Enemy
Nov 10, 2015 08:01 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
gulf gt
Aug 27, 2015 10:27 AM
TrackOne
Aug 20, 2015 12:56 PM
