PCCB to Steel brake rotor conversion options?
Old Feb 21, 2016 | 04:09 PM
P.Viby's Avatar
P.Viby is infamous around these parts
PCCB brakes are optional on all model years of the GTS and the color yellow is used for the calipers only when you have PCCB.
That goes for all the Porsche models. (Not sure about the 918)
Old Feb 22, 2016 | 11:37 AM
RacingBrake's Avatar
RacingBrake is infamous around these parts
Originally Posted by skidmarkz
2013 Panamera GTS had PCCB as an option. It is listed as an option on my build sheet. Calipers are yellow.
According to the 2014 spec sheet (linked below), the GTS PCCBs are 410mm front and 350mm rear with thickness of 38mm front and 28mm rear, but I haven't been able to find the similar spec sheet for the 2013.
http://press.porsche.com/vehicles/20...l-Variants.pdf
*EDIT* - Just measured one of my front rotors with a tape measure, and it's 410mm.
Yes, front 410mm and rear 350mm is confirmed for CCB rotors.
Old Feb 22, 2016 | 12:03 PM
Porsche's website was little confusing and your comment is correct. Essentially it's the same as 911 set up - Red calipers are for standard iron brakes, Yellow calipers are for pccb.
Old Feb 22, 2016 | 02:57 PM
negb's Avatar
negb is infamous around these parts
I don't see any confusion at all .....
http://www.porsche.com/usa/models/pa...raking-system/
997seal
Jun 8, 2016 11:23 AM
pandawest
Jan 16, 2016 08:38 PM
