Panamera Trim front/rear center counsels
Old Jun 20, 2017 | 02:08 AM
opimon's Avatar
opimon is infamous around these parts
Question Panamera Trim front/rear center counsels
Hi,
I search instruction to replace trim front/rear center counsels on Panamera 4S 2010
Can you help me ?
Thx a lot !!!!
Old Jun 20, 2017 | 05:35 AM
orangeokie's Avatar
orangeokie is infamous around these parts
What kind of trim are you wanting to replace? What material?
Old Jun 20, 2017 | 09:48 AM
opimon's Avatar
For the moment i have Wood trim. I like more carbon or alu.
Do you know how i can remove the wood part in central counsels ?
I have buy special tools to do that, but I do not want to break anything
Old Jun 20, 2017 | 03:07 PM
orangeokie's Avatar
Sorry my friend. I do not know how to remove the wood trim and install carbon fiber or aluminum.
Old Jun 21, 2017 | 01:24 PM
tonyep's Avatar
tonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of light
I did replaced the wood with OEM carbon. You have to loosen:remove the screen in order to get the center console out.
Old Jun 21, 2017 | 06:22 PM
XLR82XS's Avatar
You'll need to tackle this first: http://www.insanegarage.com/panamera...-vent-removal/ Then pull out the PCM (4 scfews) and unlock the shift ****. Twist the base of the **** to unlock it. Remove the ashtray and then you can then release the center console trim.
The rear pieces are easy. The flip-up storage area pieces are removed by pulling upwards when they are opened about at a 45 degree angle.
