Help removing sunshade/luggage cover bar
Old Jul 18, 2017 | 01:56 PM
wraithetc's Avatar
wraithetc is infamous around these parts
I have a 2010 panamera with the rear sunshade and hard luggage cover. I can get the luggage cover off by itself just fine.
I push in the tab on each end of the bar, but after that can't get it to budge out of it's "socket". I've already retracted the sunshade just fyi.
Any suggestions on what motion I need to be doing to get it to budge?
Old Jul 18, 2017 | 06:30 PM
vanbellebart's Avatar
5 Year Member
vanbellebart is infamous around these parts
As I recall, the unit telescopes after depressing the tab at the end. Hence, press in a tab, and hold the end of the bar and push it towards the other side of the car. I can take pics if this is unclear.
It took me a while to figure this out...
Old Jul 19, 2017 | 10:37 AM
Just A GTS's Avatar
Just A GTS has a spectacular aura aboutJust A GTS has a spectacular aura aboutJust A GTS has a spectacular aura about
Here you go sir.
Old Jul 19, 2017 | 12:39 PM
orangeokie's Avatar
orangeokie is infamous around these parts
Thanks . I had the same question.
Old Jul 20, 2017 | 09:34 AM
wraithetc's Avatar
Thanks for the help guys
Old Jul 20, 2017 | 10:08 AM
skiracer13's Avatar
5 Year Member
skiracer13 is infamous around these parts
I was able to remove mine, but couldn't get it back in when I tried. I'll view this video in hopes that it will help - thanks for posting!
Old Jul 20, 2017 | 10:23 AM
Just A GTS's Avatar
Click in one side first, then push it down from the top while holding the lock open for the other side. The video should definitely help.
