Porsche Panamera Turbo 2010 engine wont turn off
Hey guys and girls
First of all as I am new to this forum, and new to Porsche (1 month ago) I got a pretty Pan Turbo (pics to follow later). Drives like a dream and probably ter fastest gasoline car in my town.
this day I did however encounter a pretty scary issue. I cant turn off the engine. When I turn the key to off it seems like the electronic turns off, but the engine wont stop. Continues to rev. I finally managed to force it off by pulling the fuse on engine controle system (32) in front left panel.
the information screen says "fault transmission", "check engine" and "auto start/stop turned off".
Does anybody have any ideas on what to do next? I was thinking to pull both batteries and let it stand without power for 10 minutes and restart it so to speak?
maybe its the fuse for auto start/stop that is burned?
any suggestions or help is highly appreciated!
***UPDATE as of this morning it is completely without battery. I assume some of the electronic have been running the whole night. Although it appeared to be finally turned off, when I pulled the fuse.
best regards
best regards
first thought is that it s in the ignition itself. Not sending signal to cut off. 2010 keyless? Any mods or updates to anything recently? After the ignition you d have the DME and probably relays between them. This is going to be difficult to home trace without tools and knowledge specific to Porsche.
BlueDream996
Apr 16, 2015 08:05 PM
drhenrock
Sep 2, 2010 08:17 AM
