Dead battery recovery
From owners manual --- 2014-2016 version:
Hope this helps -- I have followed this myself after disconnecting the battery.
Chuck
'14 Panamera 4S
Putting vehicle into operation
After the battery is connected or after a fully discharged battery is charged, the PSM warning light lights up on the instrument panel and a message appears on the multi-function display in the instrument panel to indicate a fault.
This fault can be corrected with a few simple steps:
Start the engine.
To do this, turn the ignition key or the control unit (on vehicles with Porsche Entry & Drive) to ignition lock position 2 twice.
With the vehicle stationary, perform a few steering movements to the left and right and then drive a short distance in a straight line until the PSM warning light goes out and the message is erased from the multi-function display in the instrument panel.
If the warnings do not disappear, then:
Drive carefully to the nearest qualified specialist workshop.
Have the fault corrected.
After the warnings go out: Stop the vehicle in a suitable place.
Store the end position for the power windows.
For information on storing the end positions for the power windows:
Please see the chapter “STORING END POSITION OF THE DOOR WINDOWS AFTER CONNECTING THE VEHICLE BATTERY” on page 81.
Teach tires on vehicles with Tire Pressure Monitoring System (TPMS).
For information on teaching the Tire Pressure Monitoring System (TPMS):
Please see the chapter “TIRE PRESSURE MENU (TIRE PRESSURE MONITORING SYSTEM (TPMS))” on page 113.
Store end position on vehicles with a slide/tilt roof.
For information on storing the end position for the slide/tilt roof:
Please see the chapter “STORING END POSITION OF THE SLIDE/TILT ROOF” on page 83.
Chuck
'14 Panamera 4S
Start the engine.
So it means that simple battery disconnect ( not replace or recovery from dead) will lead into these issues ?
I came across this when installing KW DLC and stopped the job, actually KW manual says:
Please disconnect the battery according to the manufacturers information.
Caution:
At some vehicles it is necessary to teach the control units after reconnecting the battery. We recommend to read the vehicle
failure memory before you disconnect the battery, to exclude possible faulty sources after the KW DLC installation.
Don't understand at all what means ''read the vehicle failure memory before you disconnect the battery'' -- what for ?! Failure memory before disconnecting ? Or my English is not good enough ... What I think is that I have to know somehow if my vehicle is one of ''some vehicles it is necessary to teach the control units after reconnecting the battery'' ... saga begins ....
Caution:
that's a bit diffident story ...
Falcon7x
Aug 29, 2014 04:53 PM
