help with setting menu
Old Jun 19, 2018 | 07:38 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
I have the book for ref but since Re setting my TPMS I think I may have entered restore factory settings on everything. I have gotten all back to previous settings except for it seems like the AC / fan is always on upon start up, even if OFF when shutdown. In the menu for AC I only see vent locations and soft, med, hard for AC setting. I can t find why and if I changed a setting to be causing this AC ON function.
Thank you for insight.
Old Jun 23, 2018 | 06:41 AM
cerbomark's Avatar
Bump, still can t figure this out.
Old Jun 23, 2018 | 08:44 AM
dudecs's Avatar
dudecs is a jewel in the roughdudecs is a jewel in the roughdudecs is a jewel in the rough
Not quite sure I understand your problem. You may have to save the settings to your key?
"On vehicles with comfort memory, all air-conditioning settings are stored on the relevant ignition key when the vehicle is locked."
Old Jun 23, 2018 | 09:09 AM
cerbomark's Avatar
You are correct sir. Figured it out this morning. I had to hit the memory button on the door (seat memory/key) and there is a separate button that looks like a key.
Thank you!
solrac6262
Oct 23, 2011 08:25 PM
RickyStickers
Cayenne 955/957
Dec 22, 2008 07:09 PM
whatever
Cayenne 955/957
May 1, 2007 06:04 PM
