How to lift Panamera front off the ground without a lift
I planned to do my shock swap, and wanted to do it with two bottle jacks, but found out that even if I put something under them, they do not have enough range to flift both from wheels off the ground.
So now, i need ideas for how I can lift front of my car off the ground, without using a lift.
I have 2 bottle jacks and a floor jack.
Wonder if there is a place under the car that I can stick the floor jack under to lift entire front. Need to lift the front so that I can relieve pressure off the sway bar (lifting only one side would create pressure there).
So if you have ideas, let me know. Thank you for help in advance.
I don't do a lot of wrenching but for brakes and suspension stuff I will typical drive them up on higher end ramps made for low cars, then jack the working side up with a heavy duty jack at the proper areas. I then use a second small jack to move and manipulate components of the control arms and such as needed while leave the main jack in place. I'm not as familiar yet with the Panamera, and don't know the pit falls of jacking up with air ride, so when the time comes I will have to research that further. I'm assuming there is a service setting like my Audi had to disable automatic level and other things that can get screwing jacking up the car. Low profile ramps are worth purchasing. I also typically will put ramps reversed behind the non working wheels as a safety measure.
PelicanParts.com
991 Vendor Classifieds
Aug 31, 2016 11:26 AM
PelicanParts.com
991 Turbo Vendor Classifieds
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 31, 2016 11:25 AM
PelicanParts.com
997 Turbo Vendor Classifieds
10
Aug 31, 2016 11:07 AM
