Rear wheel play
Old Sep 11, 2019 | 10:56 AM
Gabriel Mayoral's Avatar
Gabriel Mayoral is infamous around these parts
Rear wheel play
Hey guys just recently changed my brakes on the rear of my 2010 and realized that I had a lot of play on my right side. I was wondering if I needed to replace the whole knuckle or just the bearing and if any has any DIY on it.
Old Sep 11, 2019 | 12:20 PM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
is the play just left to right or is up and down as well? if up and down as well it would be your bearing
Old Sep 11, 2019 | 12:22 PM
It moves all around
Old Sep 11, 2019 | 08:19 PM
ciaka's Avatar
Sounds like you need to do suspension refresh. control arms first. Then see if hub giving you issues. If you still have play, bearing next. Alignment critical after any suspension work.
you should have no play holding wheel 12/6 or 3/9 locations.
Old Sep 12, 2019 | 02:30 PM
I ordered a used knuckle off ebay, the car activates multiple faults such as abs/chassis/psm which I'm sure the bearing has kicked the bucket. All other suspension parts look good upon inspection.
Old Oct 9, 2019 | 06:18 AM
Update
Wheel bearing was definitely shot, decided to also go with a lower mileage spindle. All system faults see gone and there is zero wheel play. In case anyone wants to prevent this before you're without a car, my warning sign was a weird scraping noise I couldn't figure out where it was coming from after encountering a dip in Denver. Mileage is 111k+.
Old Oct 9, 2019 | 08:36 AM
DogWood's Avatar
5 Year Member
thanks for the update
mikerosi
Oct 16, 2014 10:26 PM
soreshoulder
Apr 17, 2012 06:07 PM
Cj_boxster
Apr 19, 2008 01:10 PM
Destructo
Mini Cooper
Sep 24, 2007 02:31 PM
