Driver side AC not cold
Old May 6, 2021 | 10:16 PM
vkb123's Avatar
5 Year Member
vkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond repute
Car back from dealer. Good news, bad news.
Good...A/C recharged and blowing ice cold again! They pressure tested system (low), recovered refrigerant, added UV dye to look for leaks (none detected yet), and then recharged the system. The “hissing” noise is also gone. No charge for this work. Will check for A/C leak (UV dye test) when I return for “the bad”.
Bad...timing chain cover leaking oil (AGAIN!). Had a full cam cover and timing chain cover reseal in 2017 under Porsche factory warranty after 1st bought car. Lasted 4 years...suspect incompetent work at a Porsche dealership that I no longer frequent. Thankfully have aftermarket warranty...
Old May 12, 2021 | 12:03 AM
dougcayenne's Avatar
dougcayenne has a spectacular aura aboutdougcayenne has a spectacular aura aboutdougcayenne has a spectacular aura about
I have same AC problem as VKB123. Fremont Porsche dealer performed the same AC procedure and my AC is cold now. Free of Charge. They will check for leaks when AC is not cold. my 2016 hybrid is no longer under warranty ...
Old May 13, 2021 | 01:12 AM
allroadusa's Avatar
allroadusa has a spectacular aura aboutallroadusa has a spectacular aura about
From my experience with my past two Pannys, I would say the leak will likely be located on the A/C condenser. It's exposed to road rocks and is prone to leak.
salerno713
Cayenne 958
Apr 26, 2019 12:24 PM
swampydrill
Jun 22, 2017 09:22 AM
mziegler38
Jun 18, 2017 06:04 PM
Cattman
Jun 23, 2011 08:11 AM
SCRUBEN
Cayenne 955/957
Apr 19, 2011 05:19 PM
