V6 doesnt go into GEAR!! Park Brake, Tranny, Chassis Faults & Reduced Engine Power
2012 Panamera base v6
Need help! I have access to a Launch x431+
Codes are attached (ignore inactive codes)
I have another 2011 base v6 Panamera I can use to swap parts to figure out the issue.
Parking Brake Fault, Suspension/Chasis Fault, Transmission Fault, Reduced Engine Power
*CAR DOES NOT SHIFT INTO GEAR / REVERSE, BUT I CAN SHIFT IT INTO NEUTRAL.
all gauges work(oil pressure, oil temp, fuel, coolant temp, rpms)
*starts up & idles perfect
Lights on the dash: ABS, Traction Control, Brake, check engine, parking brake, tire pressure, airbag)
*Theres No light at the parking brake button, does nothing when you push/ pull it
*checked all fuses
*oil level is good
*new coil packs / spark plugs
*new battery
*AC works
* starts up & idles perfect
*radio works
* rear spolier does not go up or down
*all lights / windows / blinkers / brake lights work
I tried swapping the gateway / battery / main relay / ecm(engine compartment, passenger side firewall)
Right now I Have everything swapped back to the originals, at first I did have a bad oil pressure sensor that I replaced, was getting no oil pressure reading(fixed now with a new sensor)
I'm assuming I have a short / bad wire somewhere but not sure where to start testing Wires, i checked the injector/coil wires when I removed the intake.
*checked all fuses
*oil level is good
*new battery
*AC works
*radio works
Yes, Transmission Fault. Most modules has a "No communication with the PSM" code and in the PSM whats sticking out the most is a Combination Sensor code. Which there's very little information online about that or what/where it is. Also it says the Combination sensor is not calibrated, every time I try to calibrate it It fails the test instantly. "Steering wheel straight, on level ground, etc"
Almo
11-23-2009 11:28 AM
