Porsche Hybrid Failure system implausible Signal Fault Code 55600
Hi All,
I recently purchase 2012 Porsche Panamera S Hybrid and I have a hybrid Fault code P055600 Implausible Signal. My garage did a Smoke test and replaced the brake sensor and brake distance sensor.
The conditions are:
- “Fault Hybrid System” yellow warning pops up.
- Hybrid system itself works perfectly when erasing the code with a code scanner, but the error comes back mostly after a restart.
- On the freeway driving ore after a reset it never fails.
- The ignition do not start at the first try (almost like it’s not detecting the brake switch), it always starts with the second attempt.
If anyone can point out the possible issues here, please help!
The conditions are:
