1970 Chevelle. Comfortable cruiser with twin turbo motor and A/C
Old Jul 28, 2011 | 05:39 PM
INTMD8's Avatar
INTMD8 is a splendid one to beholdINTMD8 is a splendid one to beholdINTMD8 is a splendid one to beholdINTMD8 is a splendid one to beholdINTMD8 is a splendid one to beholdINTMD8 is a splendid one to beholdINTMD8 is a splendid one to behold
Year: 1970
Make: Chevrolet
Model: Chevelle
Price: $40000
Mileage: 88000
Color: Black
Location (State): IL
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Up for sale is my 1970 Chevrolet Chevelle Malibu. Is this the best Chevelle ever? I don't know but it's pretty damn nice :-)
Body/Paint/Chassis-
I absolutely hate rust so I found this completely rust free Chevelle in Arizona. 100% zero rust. This car is all original panels.
Paint is base/clear and was done in 1999. Since the paint is a bit old and this car is driven there are some imperfections but overall it is gorgeous. Wet sanded and polished and is very glossy and reflective. Belt-line trim was just replaced (refurbished original) as well as the rocker trim (NOS). All new window fuzzies that are an exact match for stock.
The frame and floors were cleaned, prepped and painted semi-gloss black. Some areas were left original (firewall has original chalk marks) just because I wanted the car to have a somewhat aged look and not look completely new. Front control arms and springs are powdercoated. Steering linkage was clear-coated when replaced. Every single suspension bushing and ball joints are new. It has Hellwig sway bars and rides very smooth with Monroe sense-a-trac shocks. Wheels are powdercoated 15x7 steel. Tires were modified by Diamondback with a 1/4in white stripe. Rear tires are Mickey Thompson drag radials. I have an extra set of new rear tires that come with the car. Brakes are new booster/master/wheel cylinders/shoes. Yes it is 4 wheel power drum and many people think I'm crazy for that but I'll tell you the car stops very well, even at the drag strip. Considering that, and the fact that I had no plans to road-race this car I never changed them.
Interior-
Door panels are original and slightly faded from the sun at the top. Carpet is original. Dash is original GM that was re-dyed. New door and trunk weatherstrip. New headliner, sail panels, package tray and sun visors. Steering wheel is not original to the car but it is an original GM wheel, not a reproduction. Seats were all-vinyl but I bought some NOS Gold Rivar cloth and had a local upholstery shop sew it in and replace all seat foam. New rear window rollers. I installed 3 point seat belts and mounted the regulators behind the interior panels. I did this because the stock shoulder belt always dug into my neck and it ruined the clean hardtop look hanging down from the ceiling. Stereo is a Pioneer Premier 800prs head unit, JL VR690 6x9's in the rear deck, Pioneer D9500F 4 channel amp, and JL C3-650 front components. Sounds awesome. Engine PCM and Eboost boost controller mounted in glove box. Air conditioning system was flushed, new o-rings, POA valve re-calibrated for R134A. Air temp at the vents is 33 degrees. Horns are unplugged and an MSD 2-step is wired into the stock horn relay. To launch the car at the track you hold the brake, push the horn button then floor the accelerator. RPM's come up to 2200 and stay there until you release the horn button and off you go.
Drivetrain-
6 liter LQ9 engine, cast iron block, aluminum heads. LS6 cam, comp pushrods, patriot dual valvesprings. Edelbrock Pro-Flo intake manifold. LS7 timing chain. Twin Buick Grand National turbochargers with ported inlet bells and exhaust elbows. Garret/honeywell high efficiency air to water intercooler core, end tanks built by me. All stainless cold side tubing and all stainless exhaust system. Vintage cooler used for intercooler water reservoir in trunk. Vintage tool box used for battery box in trunk. Stock 03 cobra intercooler heat exchanger mounted up front between frame rails.
Transmission is a 4l65E built by Finishline Performance and has a stock converter re-stalled to 2600rpm which is a perfect match for the fast spooling turbos. Driveshaft is 3.5inch aluminum. Rearend is a 3.31 geared 12-bolt posi.
New baffled fuel tank with walbro 255lph pump. Kenne Bell boost-a-pump. 60lb injectors. Tuned by myself with HP Tuners 2-bar speed density operating system.
Driving/performance and other things-
The car goes down the road beautifully. Very quiet and comfortable. Gets drooled on at car shows and the dragstrip :-) All suspension bushings are new but stock rubber for a cushy ride. Steering is new/tight and brakes work great. At one point I had a set of larger Precision turbos on the car but removed them to re-install the stock Buick turbos as I prefer their instant response. With the buick turbos it makes between 555 and 607 rear wheel horsepower depending on the boost level (8-12psi adjustable) and runs between 11.20 (flat footing it off the line with no boost) to 10.80 at 123-126mph trap speeds. I calculated fuel mileage only once and on a 600 mile round trip with the A/C on it got a little over 20mpg.
http://www.youtube.com/watch?v=95W34ylIOY0
http://www.carcraft.com/featuredvehi...ck_engine.html
Pics-
http://imageshack.us/g/718/chevellebyron.jpg/
Old Jul 28, 2011 | 05:57 PM
1ofthesedays's Avatar
1ofthesedays is a jewel in the rough1ofthesedays is a jewel in the rough1ofthesedays is a jewel in the rough
O
M
G!!
Seriously, that is one of the most wicked sleepers I have ever seen!! I wouldn't change a thing. Hat's off to you my friend, that bad boy is drenched in WIN!! I sold my '70 about a year ago and still sob myself to sleep over it. If I had the $$ I would grab that beauty in an instant. If you are ever in the market for a spleen or kidney please let me know, those are two things I actually have that I would trade in a heart beat!!
MASTERPIECE!!!!
Old Jul 29, 2011 | 01:26 PM
HIRISC's Avatar
HIRISC Is a GOD !HIRISC Is a GOD !HIRISC Is a GOD !HIRISC Is a GOD !HIRISC Is a GOD !HIRISC Is a GOD !HIRISC Is a GOD !HIRISC Is a GOD !HIRISC Is a GOD !HIRISC Is a GOD !HIRISC Is a GOD !
Awesome, awesome sleeper. Well done Jim.
Old Jul 31, 2011 | 03:17 PM
INTMD8's Avatar
Thank you both for the kind words! I do appreciate it and I'm glad you like the car.
Old Jul 31, 2011 | 07:27 PM
Nthusiast2's Avatar
Nthusiast2 is infamous around these parts
Note to self:
Don't mess with any black Chevelles in Indiana>
very, very nasty sleeper. Beautiful job..
James
Old Jul 31, 2011 | 09:52 PM
ETW 360's Avatar
ETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant future
This is one of the coolest Chevelles I've ever seen. Well done. Good luck with the sale
Old Aug 2, 2011 | 06:06 AM
jjc4scab's Avatar
jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !
Ftw:d
Old Aug 2, 2011 | 02:44 PM
Surfer's Avatar
Surfer is infamous around these parts
Gotta agree that's like the perfect sleeper, not even any lope just a smooth idle like any of the new GM 8's. And it looks bare bones stock.
Old Aug 2, 2011 | 05:36 PM
IPGJames's Avatar
IPGJames has much to be proud ofIPGJames has much to be proud ofIPGJames has much to be proud ofIPGJames has much to be proud ofIPGJames has much to be proud ofIPGJames has much to be proud ofIPGJames has much to be proud ofIPGJames has much to be proud ofIPGJames has much to be proud of
wow, impressive, well done
Old Aug 9, 2011 | 02:10 PM
medici78's Avatar
medici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud ofmedici78 has much to be proud of
Aside from the brakes (yes you are crazy, lol) this is the PERFECT 1970 Chevelle Malibu!!!
Old Aug 11, 2011 | 05:53 PM
INTMD8's Avatar
LOL, thanks guys. I'm telling you though, the brakes work awesome, you would have to drive the car to believe it
Old Aug 11, 2011 | 06:08 PM
930slantnose's Avatar
930slantnose is a jewel in the rough930slantnose is a jewel in the rough930slantnose is a jewel in the rough
jim can you call mike 718 880 6065
thx
Old Aug 11, 2011 | 06:11 PM
or can you post your number ill call you
thx mike
Old Aug 14, 2011 | 07:18 PM
INTMD8's Avatar
Thanks again everyone, car is sold.
Old Aug 15, 2011 | 07:15 AM
HIRISC's Avatar
Congrats.. new owner got a great car/deal.
COBB Tuning
Jan 1, 2025 09:02 AM
racerbvd
Feb 11, 2016 12:07 PM
stevenrmusic
Bentley
17
Nov 12, 2015 05:53 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
